In the first picture, that looks like a green/white and red/blue into a T 2 conductor connector female for the heater control's light. I also have a similar connector but with green/white and red that is not plugged in right now.
Edited by Jeff Berk
The second picture shows a 3-contact connector with only the top and bottom connectors used, both wires are green. If so, that might be the map light above the vents.
For the other connector in the 2nd picture, how many contact positions, how many are actually used, and what are the wire colors?
I don't know if this helps or makes it more complicated, but here's a chart I started a few years ago. It's never been QC'ed so be forewarned.
As an example on how to read this, the "Turn Signal" circuit is on page BE-11, involves junction connectors C-2, 3, 4, and 5, Fuse #3,  which is 10 Amps, uses white, green and black wires (specifically white/red, green/red, green/black, black, and black/white).
The way I've used this is to try and match up the colors, then go the the FSM page BE-xx to read the wiring diagram.
Junction
Fuse
Wire Color (primary, secondary)
System
Page (BE-)
Block Connectors
No.
Amp
Red
White
Green
Blue
Yellow
Black
Head Light
10
1345
1
10
R, RB, RW
W, WR
Head Light
10
7
2
10
R, RB, RW, RY
W, WR
Turn Signal
11
2345
3
10
WR
GR, GB
B, BW
Haz Warning
12
12346
11
10
WR
GW
BY
Stop Lamp
13
26
11
10
W, WR
B, BW
Clearance & Tail Lmp
14
1256
5
20
W, WR
GW
B
Reverse Lamp
15
3567
9
20
RB
W, WR
LB
Meter Lights
16
246
5
20
RL
W, WR
GL, GW
B
Console Lights
17
12346
5
20
RL
GW
Interior Lamp
18
16
6
10
RL, RB
W, WR
B
Glovebox & Cig Lighter Light
19
246
5
20
W, WR
GL, GW
B
Map Light
20
46
6
10
RL
W, WR
B
Tachometer
30
345
3
10
W, WR
G
LB
B, BW
Water Temp/Pressure  Gauge
34
234
3
10
W, WR
G
YB, YW
B, BW
Amperage/Fuel Gauge
35
345
3
10
W, WR
G
Y
B, BW
Brake Warning
36
156
NA
#N/A
W, WR
G, GY
BW
Heater Illumination
53
12346
5
20
RL
W
GR, GW
B
Heater
54
35
8
10
W, WR
G
L, LR, LW
Heater
54
6
13
20
W, WR
G
L, LR, LW
Heater (resistor)
54
NA
#N/A
B
Horn
58
16
10
10
W, WR
G, GB, GR
Washer
64
3457
9
20
LR, LW
Wipers
67
234567
10
10
W, WR
L, LW, LY
Y
B
Lighter
69
146
7
20
W, WR
LW
B
Clock
70
146
6
10
RL
W, WR
B
Window Defogger
74
3567
8
10
R
W, WR
LR, LW
B
Radio
78
357
8
10
W, WB, WR
L, LR, LW
B
Theft Protection
81
146
6
10
RL
W, WR
B
Choke Warning Light
85
357
3
10
W, WR
G
B, BW
Interlock
99
7
14
10
W, WR
B
Ignition
102
35
4
10
WR
BW, BY
Interlock Relay
103
457
NA
#N/A
WR
L, LR
BR, BW, BY
Neutral Switch Warning
105
457
NA
#N/A
LgB
BY
B
Engine Revolution Sensor
106
6
14
10
W, WR
B
Emergency Switch
108
45
NA
#N/A
WR
L
Y, YB
B, BW, BY
Battery (Power Inlet)
106
14
10
W, WR
B
Junction Blocks
Green
C-1
Blue
C-2
Black
C-3
Brown
C-4
Green
C-5
White
C-6
Black
C-7
By chance, my center console and radio are out of the car so I can see my wires.
I have a green/white female, and a red/blue male bullet, but they are not being used in my car. I capped off the male to be on the safe side.
That multi-connector, if it's a 6-pin with 5 places used, looks a lot like my radio connector for the OEM radio (see photos). I noticed an in-line fuse in one of your photos so I think someone got creative with the electrical wiring on your car.
When asking questions about where a wire gets plugged into, indicate the number of connectors and wire colors including the color of the stripe if there is one.
Good luck.
Edited by Jeff Berk
added photographs
Junction
Fuse
System
Page (BE-)
Block Connectors
No.
Amp
Red
White
Green
Blue
Yellow
Black
Head Light
10
1345
1
10
R, RB, RW
W, WR
Head Light
10
7
2
10
R, RB, RW, RY
W, WR
Turn Signal
11
2345
3
10
WR
GR, GB
B, BW
Haz Warning
12
12346
11
10
WR
GW
BY
Stop Lamp
13
26
11
10
W, WR
B, BW
14
1256
5
20
W, WR
GW
B
Reverse Lamp
15
3567
9
20
RB
W, WR
LB
Meter Lights
16
246
5
20
RL
W, WR
GL, GW
B
Console Lights
17
12346
5
20
RL
GW
Interior Lamp
18
16
6
10
RL, RB
W, WR
B
19
246
5
20
W, WR
GL, GW
B
Map Light
20
46
6
10
RL
W, WR
B
Tachometer
30
345
3
10
W, WR
G
LB
B, BW
34
234
3
10
W, WR
G
YB, YW
B, BW
Amperage/Fuel Gauge
35
345
3
10
W, WR
G
Y
B, BW
Brake Warning
36
156
NA
#N/A
W, WR
G, GY
BW
Heater Illumination
53
12346
5
20
RL
W
GR, GW
B
Heater
54
35
8
10
W, WR
G
L, LR, LW
Heater
54
6
13
20
W, WR
G
L, LR, LW
Heater (resistor)
54
NA
#N/A
B
Horn
58
16
10
10
W, WR
G, GB, GR
Washer
64
3457
9
20
LR, LW
Wipers
67
234567
10
10
W, WR
L, LW, LY
Y
B
Lighter
69
146
7
20
W, WR
LW
B
Clock
70
146
6
10
RL
W, WR
B
Window Defogger
74
3567
8
10
R
W, WR
LR, LW
B
Radio
78
357
8
10
W, WB, WR
L, LR, LW
B
Theft Protection
81
146
6
10
RL
W, WR
B
Choke Warning Light
85
357
3
10
W, WR
G
B, BW
Interlock
99
7
14
10
W, WR
B
Ignition
102
35
4
10
WR
BW, BY
Interlock Relay
103
457
NA
#N/A
WR
L, LR
BR, BW, BY
105
457
NA
#N/A
LgB
BY
B
106
6
14
10
W, WR
B
Emergency Switch
108
45
NA
#N/A
WR
L
Y, YB
B, BW, BY
106
14
10
W, WR
B
Junction Blocks
Green
C-1
Blue
C-2
Black
C-3
Brown
C-4
Green
C-5
White
C-6
Black
C-7
Really nice idea for a database/practical way to speed up troubleshooting work.
Ya. I see the original radio plug.  They clipped the white black speaker wires and used the blue for power.  Most of my stuff worked on the console but I’m still trying to solve the horn power antenna heater fan gauge lights all have no power. Should I try contact cleaner on fuse box ? And is there a way for me to make sure my horn relay is ok as it’s almost impossible to get out.
The test light probably goes out because you're measuring the side with the resistance of the solenoid coil.  When you complete the circuit and the current passes through the contacts the voltage through the solenoid drops too low to light the light.  What kind of test light do you have?
Another way to test the horn relay would be to connect it to one of the horn wires, at the horn location at the front of the car.  Then press the button.  The light should light.  If it does the relay works.
Can't be sure.  Not looking good.  If you're getting power at the horn button wire then the connections on the way to the horn wire should be good, they use the same plugs, in and out.  It might be that the light is going out because the solenoid coil is bad.  The heat from grounding the circuit opens the circuit.
Can you trace the green wire from the C-6 connector and see if it gets to the horns?  That would be a clue.
ok  - i will get under there and see if i can trace the wires...  ONE more thing,.. I DID remove the electronic ignition unit when i put in the new dizzy...  does unplugging the Elec ignition box and taking it out of the car effect any other devices or wiring in the car? there is no ground there just a dangling plug... is that ok???
also when testing fuse box i only used tester with light... should i use a multimeter to  see if i am actually getting 122 volts accross??
Edited by Shawninvancouver
  • Who's Online   2 Members, 0 Anonymous, 1,305 Guests (See full list)
