That DVD method doesn't work with the newer style needle valves. You can't turn them up side down and set the distance then install them. They'll be way off. The newer needle valves are too sensitive for the weight of the floats. You have to turn them right side up and let the float hang down, blow through the fuel inlet while raising the float until it shuts off, no more air gets through. When you get there that's the .55" measurement.
Like Captain says that'll get you in the ballpark but the clear tube will get you a real idea of where the fuel levels are.
1972 Float Adjustment ... - Page 3 - Carburetor Central - The Classic Zcar  Club
On 6/26/2021 at 5:45 PM, siteunseen said:
The carbed cars don't have fuel pressure regulators like the efi ones do.
I have a regulator and assumed it was on all 260z's. I attached a fuel pressure gauge and was told to keep the fuel pressure below 4.5 psi. I guess what I'm saying is to check your pressure especially if you have an electric fuel pump and mechanical pump both running.
I always forget about the 260s and my lack of knowledge about them. I don't think I've ever even seen one in the "wild". Just at ZCON and on the internet.
As @Captain Obvious has mentioned in the past the "fuel pressure regulator" in a stock 240Z or 260Z is the orifice on the return line of the fuel rail. The 280Z was the first with a stock FPR.
Yes, there is an "on-purpose" restriction on the end of the return side of the fuel rail right where it transitions to the rubber hose (over by the fuel pump). It's a swaged down tip brazed onto the end of the return leg.
I've got all kinds of pics of all kinds of carb stuff, and I can't find a single detailed pic of that orifice restrictor.
So, all I've got is this:
I'll take a look to see if I have any 240/260 fuel rail stuff around here. Not sure I do, but I'll look.
You pointed it out, I found it then. Now I understand. Thanks.
Yup! There it is! Thanks for the pics!
So that little hole partially blocking the return line of the rail is what provides the fuel pressure to the carbs. If that return line wasn't necked down like that, the pressure in the rail would be pretty much zero and the carbs wouldn't get any fuel. That orifice provides the restriction which generates the pressure in the rail.
I wonder how much pressure the original electric pumps for the carb'ed cars generated.  The system started with the mechanical pump that relieves pressure at the pump itself through internal valving.  They hit a pressure and just don't push anymore.  What did Nissan specify for the pressure of the factory electric pump?
  • Who's Online   1 Member, 0 Anonymous, 1,414 Guests (See full list)
