mine was rusted and got pushed in..need a new one .. does anyone know how i can access the wires from under drivers kick panel?? is it hard? can they be fished out?? are they in the area right by relay for flasher? any ideas???
got it out by foot area...why is drivers 3 wires passenger 2 wires??
Edited by Shawninvancouver
The switch is not grounded to the frame. One of the three wires is providing power, the other two wires go to (1) the warning buzzer that the key is in the ignition and (2) the dome light. Putting all three wires together will defeat the switch - the buzzer and light will always be activated.
5 hours ago, Shawninvancouver said:
Will the power wire be live with key on or straight to battery?
The power wire should be live all the time so that the dome light comes when either door is opened.
34 minutes ago, jfa.series1 said:
The FUSED power wire should be live all the time so that the dome light comes when either door is opened.
Jim, had to edit your response.
The fuse is in the fuse block.
From the factory.
(In the spirit of I went downtown, to look for a job... but there was no job)
  • Who's Online   1 Member, 0 Anonymous, 1,275 Guests (See full list)
