240zforfirstcar Posted June 10, 2003 Share #1 Posted June 10, 2003 my 73 240z needs a right fender and control arm maybe some other miscellaneous steering compontants. there is a 280z in the junkyard and the fender looks good and i was wondering if the fender and steering stuff would fit? it all looks like it would so does any one know for sure? thanks mike Link to comment https://www.classiczcars.com/topic/6567-swapping-280-to-a-240-body-and-steering/ Share on other sites More sharing options...
kmack Posted June 10, 2003 Share #2 Posted June 10, 2003 The fender should be the same. You should be able to mount it on the 240 with out any problems.According to the parts CD (blatant merchandise plug for this site), the tie rod ends and control arms are the same from '70 up to '78. The parts numbers changed once on the control arms, but it just references back to the first part number anyway. I say go for it. Link to comment https://www.classiczcars.com/topic/6567-swapping-280-to-a-240-body-and-steering/#findComment-40473 Share on other sites More sharing options...
240zforfirstcar Posted June 10, 2003 Author Share #3 Posted June 10, 2003 thanks kmack Link to comment https://www.classiczcars.com/topic/6567-swapping-280-to-a-240-body-and-steering/#findComment-40481 Share on other sites More sharing options...
