On 8/13/2021 at 5:41 PM, Zed Head said:
Here's something I tried on a spare tire locking nut that worked.  Find a socket that fits over the nut but has a small gap between it and the nut.  Fill the socket with a ring or blob of SteelStick, press it over the nut and let it cure.  You've just made your own "key".  It is amazingly strong stuff.
https://www.jbweld.com/product/steelstik-epoxy-putty-stick
This will work if you give it time to cure to full hardness.
Are you sure it's not a 10 spline?
https://www.brandsport.com/bmcc-79241-1.html
Or 8...
https://www.brandsport.com/search-results.html?query=+Spline+Lug+nut+key%2C+Wheel+lock+key+&x=91&y=23
Edited by Zed Head
It’s a 9 spline.  I do not have a welder.  It’s not a full spline down the whole length of long lug. It’s smooth like a cone most of the way then tiny grooves at the bottom.  I have hammered a socket on there so bloody hard.  Then tried to hammer the socket wrench. It keeps slipping off as it’s on a smooth lug.  I will try to dremsl flat sides on the end to get an open ended wrench on.  I would just like to find the bloody key.  Not on Amazon or eBay or even in the 16 part key set.
Can you post a picture from the side?  A person can see the square shapes at the bottom but they don't look very deep.  Sure does look more like a cap on a nut.  Have you tried grabbing it with Vise-grips and pulling it off.
Maybe it's the angle...
but from the photograph, it appears that some one of the splines might be of a differing width.  Especially comparing the ones in the 10 o'clock and 11 o'clock position.  I suspect the manufacturer alternated the position of the narrow and wider splines to create more variation in what key would fit. Consequently, even if you source a key, having it match the correct spline sequence would be a stroke of good luck.
They probably went out of business because the design worked so well that if you lost the key you were screwed until you could get a new key.
If you had a long drift (aka drift pin) and were handy with it and the end was shaped right you might be able to turn it that way by pounding on a projection.  But, any slips and you're gouging the rim.
https://www.grainger.com/product/4RPL7
Edited by Zed Head
A longer cheaper one.  The long punch is very useful, I have this set.  I still think the SteelStik has a chance.
https://www.harborfreight.com/12-piece-punch-and-chisel-set-66337.html
Edited by Zed Head
