While driving my 280zx from a dead stop , I heard a thump,thump (on off) sound from the driver's rear tire area. It sounds like some parts are moving around due to the motion. On the road at speed there is no problem. From a stop sign or at low speeds the sounds happens. Bad shocks?
https://www.classiczcars.com/topic/65747-rear-wheel-noise/
Maybe the brake pads have (normally) a little play and are dry? just a good clean and some coppergrease behind the pads needed?
Something stuck inbetween the brakes?
Otherwise make a vid with the sound..
https://www.classiczcars.com/topic/65747-rear-wheel-noise/#findComment-627417
Tire store said the bushings on the left strut are worn out. Where to buy the rear strut assemblies for the 79 280zx. He could only find the strut inserts, no assembly
https://www.classiczcars.com/topic/65747-rear-wheel-noise/#findComment-627444
  • Who's Online   2 Members, 0 Anonymous, 492 Guests (See full list)
