1 hour ago, Wally said:
wait a minute. so that adapter plugs off the voltage connector and thus eliminates it? is that right?
The adapter bypasses the stock external voltage REGULATOR as the "high output" alternators are internally regulated. If you have both an external and internal voltage regulator in the circuit, the internal VR won't see the battery voltage, so it jacks up the output voltage.
As SteveJ said, it's for the external regulator plug.  MSA should have them in stock.  😁
"It is small, weather-resistant, and simply plugs into the wiring harness in place of the original voltage regulator."
On 9/12/2021 at 12:39 PM, Zed Head said:
cant seem to find anyone else selling this? does anyone know another place? Zstore is out of stock and no clue when or if they will get any more.
