ennisdavis Posted September 4, 2021 Share #1 Posted September 4, 2021 Can you guys help me id some of these parts? Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/ Share on other sites More sharing options...
siteunseen Posted September 4, 2021 Share #2 Posted September 4, 2021 (edited) I see a lot of behind the dash parts. #11 is the dome light. 1 thru 6 looks like the stuff behind and around the heater control panel? The middle of the dash where the transmission tunnel is. Edited September 4, 2021 by siteunseen Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628058 Share on other sites More sharing options...
Mark Maras Posted September 4, 2021 Share #3 Posted September 4, 2021 #4 looks to be a radio bracket. Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628059 Share on other sites More sharing options...
ennisdavis Posted September 5, 2021 Author Share #4 Posted September 5, 2021 #4 is not the radio bracket. There are 2 pieces. Smaller then door handle. Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628062 Share on other sites More sharing options...
Patcon Posted September 5, 2021 Share #5 Posted September 5, 2021 (edited) #4 look to be the metal pieces that go over the rubber pockets at the hatch hinges #8 look to be generic hinge shims #17 looks to be a master cylinder reservoir cap #1,2,3 & 5 look to be dash brackets #9(edit) looks to be brake booster vacuum line #10 might be glove box light switch Edited September 5, 2021 by Patcon 1 Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628064 Share on other sites More sharing options...
Captain Obvious Posted September 5, 2021 Share #6 Posted September 5, 2021 1 and 10 are for the glovebox. 1 is part of the latch mechanism, and 10 is the light for inside when you open the door. 2 is (I believe) the brackets the hold up the center of the dash. One end screws to the trans tunnel and the other end screws to the underside of the dash. 3 is the radio support bracket. Not sure about 4 and 5. 6 is a bracket that holds the center dash panel (with the two HVAC outlets and your FUEL light) in place. There should be a second one that is a mirror image. 7 is a bracket for your coil wire. 9 is one of the vacuum lines that run to your power brake booster. 11 is your roof mounted dome light. Missing the white lens. it's probably turned to dust. Not sure about 12. Obviously a vacuum hose, but not sure which one offhand. 13 is one of the clips that holds your shifter boot in place on the underside of the console. Not sure about 14 and 15 Not positive on 16, but I think it's a window roller. Should be inside one of the doors maybe? 18 is your FICD. Fast Idle Control Device. It pulls the throttle open a little bit when you turn on the A/C 2 Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628066 Share on other sites More sharing options...
EuroDat Posted September 5, 2021 Share #7 Posted September 5, 2021 18 is fast idle for AC. Sits on top on inlet manifold and activates when airci is running to maintain idle. 1 Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628079 Share on other sites More sharing options...
dutchzcarguy Posted September 5, 2021 Share #8 Posted September 5, 2021 👏 Applause ! You guys are good.. next time make more pics BEFORE and DURING taking the car apart.. 🙂 1 1 Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628084 Share on other sites More sharing options...
ennisdavis Posted September 5, 2021 Author Share #9 Posted September 5, 2021 I agree. Bought the car cheap but.....was in boxes. Sucks Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628106 Share on other sites More sharing options...
EuroDat Posted September 6, 2021 Share #10 Posted September 6, 2021 I found this photo in my tablet. It might help locate other parts. I circled part 7. Mine is a 77 model so the engine bay will be a little different. If you need any detailed areas, let me know and Ill post them here. 2 Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628134 Share on other sites More sharing options...
zspert Posted September 11, 2021 Share #11 Posted September 11, 2021 Banzai Motorworks has reproduced the 280 valve cover breather hose which has been NLA for more than 5 years. It's $45.00. Link to comment https://www.classiczcars.com/topic/65786-1975-280z-parts/#findComment-628356 Share on other sites More sharing options...
