JLPurcell Posted September 6, 2021 Share #1 Posted September 6, 2021 I am in need of the fasteners for the rubber bushing retainers for the brake, fuel, and clutch lines. Does anyone have or know of someone who might have a set. Are they still available? Thanks in advance for your consideration. Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/ Share on other sites More sharing options...
Patcon Posted September 6, 2021 Share #2 Posted September 6, 2021 The little tiny hex head bolts? Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628158 Share on other sites More sharing options...
CanTechZ Posted September 6, 2021 Share #3 Posted September 6, 2021 They are M4 like this, not sure of the length. I think they only have a lock washer https://www.clipsandfasteners.com/M4-0-7-x-8mm-Phillips-Hex-Head-SEMS-Screw-p/pm33209.htm Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628159 Share on other sites More sharing options...
jfa.series1 Posted September 6, 2021 Share #4 Posted September 6, 2021 Hi Jerry, I did a quick check on my car - the tiny bolts are a 7mm hex head with a phillips slot. Checking with Belmetric, it looks like they are called SEMS Hex Phillips altho these have a flat washer installed. They carry it in a 6mm head but not 7mm. https://www.belmetric.com/sems-hex-phillips-c-10_2345/?zenid=2tdb29vtv11hqsruk3uf0dsk12 Interesting that Nissan used a odd number mm head when everything else is even number. Jim 1 Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628160 Share on other sites More sharing options...
CanTechZ Posted September 6, 2021 Share #5 Posted September 6, 2021 (edited) I thought all of my screws were deep in my crawl space but I found one, length is 12mm and it is an M4 x 0.7 with a 7mm hex plus JIS phillips head as @jfa.series1 mentioned. Jim I think the screws you linked to are M6, not 6mm hex head. It does seem they are like SEMs but with a lockwasher only, at least it is that way on my 7/70. Just checked and Clips and Fasteners has them in 12mm long as well. https://www.clipsandfasteners.com/M4-0-7-x-12mm-Phillips-Hex-Head-SEMS-Screw-p/pm33211.htm Edited September 6, 2021 by CanTechZ 2 Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628162 Share on other sites More sharing options...
jfa.series1 Posted September 6, 2021 Share #6 Posted September 6, 2021 11 minutes ago, CanTechZ said: I thought all off my screws were deep in my crawl space but I found one, length is 12mm and it is an M4 x 0.7 with a 7mm hex plus JIS phillips head as @jfa.series1 mentioned. Jim I think the screws you linked to are M6, not 6mm hex head. It does seem they are like SEMs but with a lockwasher only, at least it is that wat on my 7/70. Just checked and Clips and Fasteners has them in 12mm long as well. https://www.clipsandfasteners.com/M4-0-7-x-12mm-Phillips-Hex-Head-SEMS-Screw-p/pm33211.htm You are correct. In my haste I misread the specs as a 6mm head but it is indeed a M6 screw dia. Thanks for catching my mistake. Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628163 Share on other sites More sharing options...
CanTechZ Posted September 6, 2021 Share #7 Posted September 6, 2021 7 minutes ago, jfa.series1 said: You are correct. In my haste I misread the specs as a 6mm head but it is indeed a M6 screw dia. Thanks for catching my mistake. You're welcome. Funny thing is when I was doing a quick search for these, that was the first link I found and almost posted it as well. Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628164 Share on other sites More sharing options...
Zup Posted September 6, 2021 Share #8 Posted September 6, 2021 https://jdm-car-parts.com/collections/hardware-parts-nissan-datsun-fairlady-z-240z-260z-280z-280zx/products/brake-clutch-line-holder-bolts-x10-set-jdm?variant=643769873 1 Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628169 Share on other sites More sharing options...
Patcon Posted September 6, 2021 Share #9 Posted September 6, 2021 Is clear zinc the correct finish? Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628171 Share on other sites More sharing options...
JLPurcell Posted September 6, 2021 Author Share #10 Posted September 6, 2021 1 minute ago, Patcon said: Is clear zinc the correct finish? Honestly I don't know if yellow or clear is correct? Anyone? Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628172 Share on other sites More sharing options...
JLPurcell Posted September 6, 2021 Author Share #11 Posted September 6, 2021 1 hour ago, Zup said: https://jdm-car-parts.com/collections/hardware-parts-nissan-datsun-fairlady-z-240z-260z-280z-280zx/products/brake-clutch-line-holder-bolts-x10-set-jdm?variant=643769873 Zup, thanks for the lead! Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628173 Share on other sites More sharing options...
JLPurcell Posted September 6, 2021 Author Share #12 Posted September 6, 2021 35 minutes ago, Patcon said: Is clear zinc the correct finish? It seems that clear zinc is correct. At least that is what is on the 70 - #00869 in my driveway. JLP 1 1 Link to comment https://www.classiczcars.com/topic/65797-needed-fasteners/#findComment-628174 Share on other sites More sharing options...
