Finishing the inside of door (under the door panel)
Three questions on this:
I have some leftover Thermo Tec. Has anyone seen any benefit in applying this to the door?
The openings in the door were each covered with homemade plastic covers that I made 20-30 years ago out of 5 mil Mylar, but I don't remember if I was replacing factory-original covers.  Were these original?
The entire door was covered by a 'watershield', but I remember even less about that.  The FSM only mentions that it exists, but doesn't illustrate it.  I think it was a thin plastic sheet secured on the top and sides (but not bottom).  Does that sound right?
Thanks in advance...
