What valve specs y'all like for adjusting
19 minutes ago, Yarb said:
Talk to me about the Silicone valve cover gasket. Interested to know why you would not go back to the factory gasket which is reusable. Thanks for your time…john
I bought a stock gasket, and it was already seeping oil mostly just sitting for the past couple months. The silicone one came from MilkFab
Edited by HusseinHolland
  • 10 months later...
Not good - this gasket is coming apart - just noticed this spread. Driving about 500 miles round trip next weekend to the Carlisle Import Show - so I've ordered a Mahle cork/rubber version to tide me over. I've emailed MilkFab.
There's a little difference on the sides up front. Look close when you put it on. I put one on upside down and the thermostat housing side was a little longer on the staight part before the cam sprocket hump.
Yes - I got that - you can see the shoulder placement in my second pic - when reversed, it is stretched on the area between #1 & the cam chain
  • Who's Online   3 Members, 0 Anonymous, 826 Guests (See full list)
