You will need 7mm X 1.0 and 10mm X 1.0. Sorry, I can't remember which size is which for the calipers and the drums. I bought these from Amazon: Russell 639560 and Russell 639570, both are produced by Edelbrock and worked out very well.
I can't get the front brake circuit to produce any bubbles in the fluid. I replaced the brake booster, master cylinder, and pads and shoes. I have some resistance in the pedal, but have to push it twice for usable braking.
I've been using the type bleeder that connects to my compressor and then sucks fluid out through the bleeder screw. It wasn't working, so I bought another one, different brand, with the same results. The reports of the speed bleeders are positive, so I thought I'd give that a try. They have been ordered from Amazon, so I should be back on the road soon.
Thanks to all for the prompt and accurate advice.
Joe
  • Who's Online   1 Member, 0 Anonymous, 872 Guests (See full list)
