is this an early 260z or a late 260z? The early 260z might share brake lines with the late 240z. the fuel lines might be different, i can take a look at my late 73 chassis and compare to my early 74... in which case https://classictube.com/model/240z-7/ might work...
https://www.classiczcars.com/topic/65911-260z-hardlines/#findComment-629766
  • 6 months later...
Definitely stay away from the stainless.  Not sure what the issue is but just with gravity feed through the master I had leaks at the MC and the unions. Just received the OE replacement lines. I’ll report back once installed. I can tell you the OE is much more flexible than the stainless.
https://www.classiczcars.com/topic/65911-260z-hardlines/#findComment-639476
  • Who's Online   1 Member, 0 Anonymous, 1,472 Guests (See full list)
