Resolved: Tail Lights Stuck On
Hi Guys,
1977 280z. Just got back from a drive and I can’t get the rear tail lights to turn off even when the car is off and the key is out. The headlights and side markers turn on and off as expected, just the tail lights are having an issue.
Not sure what fuse this is linked to, but I tried pulling a few to see if I can turn it off to no avail.
1. Any idea what fuse tail lights are linked to so I can at least get them off so they are not running down the battery?
2. Any advice on where to start with troubleshooting?
Edited by Muzez
https://www.classiczcars.com/topic/65992-resolved-tail-lights-stuck-on/
  • Muzez changed the title to Resolved: Tail Lights Stuck On
10 minutes ago, SteveJ said:
You'll need to find a longer bolt. The part is 46518-21000. It is NLA. I'm surprised that Steve Nix hasn't made a reproduction. @nix240z Is this something you might be making in the future?
Thanks @SteveJ. I didn’t see a bolt in the pedal or on the floor, but it might have shot out when the rubber part failed. But I can find a new bolt.
2 hours ago, SteveJ said:
You didn't see something like this on your brake pedal?
The issue is with the little rubber stopper. I don’t see it in your diagram.
This is what it looks like with the piece missing 85C269AD-D95A-4983-8208-5FDACE38EA78.jpeg
This is the rubber piece that popped out, it’s missing a backer piece which holds it in place.
This is what it looks like glued in as a temporary fix
  • Who's Online   2 Members, 0 Anonymous, 1,262 Guests (See full list)
