when i'm reinstalling my fuel pump after rebuild is there a need to go over or under a cam in the block or do you push it straight in. i'm asking because it's not feeding fuel to the carbs and i don't believe that the pump valves are installed incorrectly. any help is appreciated.
https://www.classiczcars.com/topic/66001-mechanical-fuel-pump-reinstall-72z/
You just push it in and wiggle it a bit. If there's lots of resistance your on a lobe and if it slides right in you are between a lobe. Either way, it'll start pumping as soon as the engine spins.
To rule out fuel flow disconnect the line between the carbs and mech pump. Have a friend crank the car and watch for fuel flow. A bucket is handy at this point.
  • Who's Online   1 Member, 0 Anonymous, 1,584 Guests (See full list)
