10 hours ago, 280zdude said:
how do you recommend I flush the rust out of the channels.
You should have done it before opening, but you can do it after you close it.. head on and clean the waterways.. I never had a clogged up engine but maybe someone here can say what to use besides lots of water..
20 hours ago, Zed Head said:
Air conditioning magnet valves (solenoids) and vacuum reservoir.  Take care of those parts, and the hoses.
How do I take off the electrical connectors? I don’t want to break anything 😅
I'm not sure but I think that you just peel the rubber boot back and pull them straight apart.  That's how other connections are up there.  Here's a thread with a picture of a set unplugged.
This worked! I didn’t peel the rubber back due to how brittle it was sprayed it with a little silicone before pulling
This is how I’m flushing the engine out.. hoa says I can’t do anything outside.
so I got tarps and taped it so water drains out of my garage. Plugged all the holes and I’m using an air compressor to flush the system with water. I had put vinegar into the the system for a few days before doing this.
look at all the hard Sediment that came out!
I will repeat until I see no more color in the water then I’ll remove the expansion plugs and do a visual check and flush
caution dirty water will go everywhere.
