Hello, I am new to the forum and just joined today since I picked up my first Z car today. A little about me, I live in Pennsylvania (Lancaster) and have been working on cars since before I got my license (20 years). I've done a ton of body work and a good amount of mechanical. I don't have the patience for electrical work but I am working on it. My daily driver is a Ford pickup, my other daily is a F80 M3, and I have a few Ducatis for some extra fun on the side... 😃
So as if that wasn't enough, I decided its time for a new project and picked up a '76 280Z. The car seems very straight and solid but the previous owner put the body in primer so I don't know what demons could be lurking underneath. But from feeling around the inside of all accessible panels, there is little to no rust. The floors look solid except for maybe a couple "half dollar" sized patches that need to be addressed. From the previous owners description, this is what I got:
Tokico suspension (not sure what that consists of as I have not gotten under the car yet), polyurethane bushings throughout all the suspension, New Brembo brakes all around, new u-joints on axles, all new steering components (again not sure what that consists of), high flow fuel filter, new brake master, new clutch master and slave, and Rota wheels. The inside of the tank has been cleaned and sealed as well. The engine is not original but I have a stack of maintenance records for the engine in the car. Additionally, I got two extra transmissions, two complete heads, and about 5 boxes of extra parts from partouts he has done.
My plans for the car are to strip it down to the shell, have it media blasted, paint it, and reassemble. This seems like a $^!# ton of work the more I look at the car but I am not a fan of the original Burnt Brown/Orange color, not sure what to call it. Anyone have any input on how bad this job actually is? I also plan to buy a block and build a complete turbo motor to swap in using one of the extra heads, likely using megasquirt but open to suggestions.
The motor runs well with an occasional misfire and the driveshaft occasionally makes some noise where it goes into the trans (the first time I heard it, I thought I was scraping the front bumper on the driveway). Since I plan on pulling the engine and trans, I will do a refresh on both, any suggestions on what to look out for or what to address first?
The intent for the car will be to have a good weekend driver that I don't feel embarrassed of in case someone starts looking at it closely, hence why I want to strip the shell, fix all imperfections, and do a complete paint job. That said, while I trailered the car home today, I had multiple people nearly break their necks looking at the car in its current state.
I am open to suggestions and am open to hearing your thoughts, good, bad, or indifferent on my purchase. While I know proper forum etiquette and using the "search" function, please be patient if I ask any stupid questions in my haste to get the car done... Much appreciated.
https://www.classiczcars.com/topic/66062-new-to-me-280z/
Hi, welcome to the forum. First thing... DO NOT lift that car the way on the picture!  Lift it under the original jack points if the car is not rusted inside there or the safe way is under the axles !!!   One day you will have a problem with the floor all dented in because its very thin steel and not strong enough to support a complete body with everything (engine and trans is ) IN it!
When you have a completely stripped chassis it could be possible to lift it that way but not a complete car..
Buy yourself a service manual or get one on www.xenonzcar.com
(And yes the front is partly lifted the way you did in the servicemanual but i've seen to many dents there to say it's safe to do so..)
I always lift it on the axles.  (I can also lift mine on the orig. jack points because i welded my car's sides and bottom almost from scratch haha.) but when i'm in for a MOT (Here called a APK) i always let them lift it on the axles.
  • Agree 1
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632031
Looks like a sweet starting point! @dutchzcarguygave good advice with the FSM and jacking points. I'll add the EFI bible (if yours is still running fuel injection) https://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf and this book helped me alot too L Series Rebuild
Welcome! 😄
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632052
thanks for the tips @dutchzcarguy . The pics I posted were from the previous owner but I will be sure to follow your tips! I have a few manuals that came with the car so I will be sure to read up on them.
@Barefootdan Thanks for the reference and yes I am on FI. I'll read up on it!
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632082
The more I think about it, I am considering skipping the media blast and just strip the car down to the shell and paint over the existing conditions. Seeing as the car seems fairly solid throughout, I am convincing myself out of opening a can of worms by doing the media blast. I can tell that there has been some bondo applied around the windshield area and throughout the body but nothing major, presumably to cover up surface pitting due to rust areas. As I mentioned previously, the inside of the panels feel solid. All in all, the work done to it seems like it was done correctly maintaining the proper body lines. The only reason I mention the bondo work is because I can see the sanding marks through the primer. Not a huge concern as I can work them out. Anyone have any advice? Open the can or let sleeping dogs lie?
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632083
If the groundwork is good but your not sure..
This is a good test.. take the paint of at this place (windshiels area.) and when you discover clean steel you know that the rest will be probably okay to! If there is a lot of Feo... Fe2o3...  (chemist joke..) say: RUST !! ... then you know you have to take it all down because your car will be a mess in a few years after your costly paintjob!
Yep.. again.. you don't know that for sure... unless you have X-ray eyes! 🧐  Just pick a few spots where you think it's gone wrong.. you will discover the quality of the work already done..
Makes no sense to paint a car that will rust again just because the groundwork is sh**..  I painted a car and took it from clean steel.. costed me some 7000+ euro's but i have had many thumbs up!
Here on the forum i did a " Datsun 280zx slickroof 1979 2+2 restauration"  (look it up!) and started from this..  (i bought this car because it had almost no rust.. for a dutch car almost impossible due to the climate!)
Unbelievable clean..
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632089
13 hours ago, dar5052 said:
When I turn the wheel, I rub on the front bumper.
Looks like you have bigger wider wheels also.
The wheels on the Z's sit forward in the wheelwells.  It bothers some people and they try to center them, but that takes a lot of work.
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632112
Finally made it back to the shop today to clean up and catalog all the parts I got with the car. Then looked around the car a little more and it looks like the engine is a reman from ATK. Still has the tags on it.
I inspected the body a little more and it looks like there is some filler on the rockers but not a lot. All in all the body is solid. I then started the car and the first time it started up just fine... however, the second time it started and shut back off. I restarted it and it was running really rough, like a bad misfire on a couple cylinders. I didn't have time left in the day to start diagnosing it but I took a look around and noticed oil around the spark plug on cylinder 6. I removed the plug, which was very loose, and could see evidence of oil on the threads and around the spark plug well. I suspect there is a valve stuck open or not fully seating or worse, the piston rings are shot or seized up. Any suggestions? The car ran beautifully last week when I put it in the garage.
https://www.classiczcars.com/topic/66062-new-to-me-280z/#findComment-632221
  • Who's Online   1 Member, 0 Anonymous, 1,444 Guests (See full list)
