how to protect fenders when working in the engine compartment
15 minutes ago, z8987 said:
How do you protect your fenders paint etc when working in the engine compartment ?
I use a Studebaker mechanic's fender protector that I've had for decades.  You can get a Summit Racing one here:
https://www.summitracing.com/parts/sum-3619?seid=srese1&gclid=CjwKCAiA0KmPBhBqEiwAJqKK4_3wvyOTSMops8wieCQvdKZVA8EBRKX_WeZ4JRrt1wVBMQJZr_rWBBoCu-8QAvD_BwE
I bought some paint dropcloths, runners is what they call the size I bought. When I'm leaning on those tin can fenders I put the hardest carboard in between the dropcloths, sandwich style.
I want nice fender protectors but that was cheap for me at the moment. Now I don't need anything since I'm done.
Found some pics...
Edited by siteunseen
I use regular fender covers, and gaffer’s tape to hold them from slipping.
I found the type with magnets would get bits of metal on them, and it would scratch the finish.
I also try to avoid leaning on the fenders, as they dent quite easily.
Edited by Racer X
I raise the front up as high as I can before I start. Ramps are the easiest but sometimes jack stands. I'm a bad leaner when fooling with the SUs.
It took me a year or so to figure this out but Imma kinda slow.
I bought a universal front end cover and cut it to fit my car.  I really like that it stays put. I cut it so that it drapes inside the fender a bit. Also note that even my windshiled is protected, but I did have to cut it to allow the doors to open.
https://www.calcarcover.com/product/fender-gripper-universal-front-end-cover-fec2607/3169
(Mine is much older than the one in the link. Buts still a Fender Gripper)
Now... if I could only get around to putting the engine back together and get this car running. It has been too many years.
Edited by 240Z-Fan
  • Like 3
