I've read the Australia Z car clubs DYNO nite with different Z cars with the different setups.*very interesting*
Have many people had there Z car dynoed OR taken it to the strip?
If so can you please list your different mods, stuff like
Heads ie:which head,how much porting(details),valve seats(3 angle etc),polished?-compression etc
Cam:how big? lift? brand? details on cam timing(verier wheel?)
Carbs(or injection):details of jets/needles /ported manifold?
exhaust: size/press bends/mandrell?
ignition:type/which dizzy/total advance etc?(sparkplugs etc?)
Pistons: Std/flattop aftermarket,oversize
Other info:stroker cranks/turbos(boost/size of turbo etc) and of course how the car drives!
What Hp did the dyno get(what type of dyno)? Or what quarters do the car get?
All this would be a wealth of information, and would help all who plan to do some thing with their beloved L series motor without wasting money on engineering that has little gain.
(even if you have a mates car thats been put on a dyno/or strip please give details)
https://www.classiczcars.com/topic/6657-l28s-wots-mods-for-dynoquarter/
It was a while ago, but I'll try & remember....
L24 Turbo....
Heads ie: 260Z E88, 8.0:1
Cam: Stock 240Z
Carbs(or injection):Custom EFI manifold, Haltech E6A
exhaust: 2.5" Stainless Mandrel
ignition:Custom Built dizzy, ECU controlled (have specs somewhere....)
Pistons: L24 Dished (ie non-240Z L24)
Other info:TO4, N-trim Turbine, 0.60 A/R Compressor 14psi boost. AiReseach Imntercooler. Laggy (but fast)....
Modified 3-speed auto, 3.9:1 open R180
120kW on Dyno-Dynamics. 0-100 (0-62) ~6s
And the setup that is almost complete....
L28 Turbo
Heads ie:N42 8.4:1
Cam:L28E
Carbs(or injection):L28E N/A EFI, SK's J-pipe.
ignition:the same dizzy as above....
Pistons: std L28E
Other info:VG30 T3, T4 Compressor, 6psi, AiResearch Intercooler. What's lag? full-boost ~2000rpm....
Modified 3-speed auto, modified 4-speed auto. 3.54:1 open R180, 3.9:1 open R180, 4.375:1 LSD R200
~115kW with 3.9:1 R180 & 3-speed. ~105kW with 3.54:1 R180 & 4-speed.
We'll see what it's like with the bigger intercooler, exhaust & 4.375:1 LSD
(This engine had been run in my Skyline for a few years & is being transplanted into my Z)
Yes I'm still building my 3.1L TT engine:
http://www.versadev.com/ben/twinmanifold.jpg
Out of date image of my Z @ http://www.versadev.com/ben/DSC01398.JPG
Those numbers for the turbo L28E seem low?
I have seen the dyno sheet for a lucky bastard with a lightly worked L28E NA making 124rwkw...I hope mine will do the same but the range of power figures people seem to pull varies so much :stupid:
Bearing in mind that a fresh L28E with auto box & 3.9:1 diffproduced 68kW @ the wheels on the same dyno...
I'ts not a powerhouse, but remember that it's just 6psi into an otherwise stock motor. Generally for each pound of boost, you can add 7% power.
  • Who's Online   2 Members, 0 Anonymous, 1,552 Guests (See full list)
