I'm in the middle of stuffing a cheap AA powered quartz clock into mine since cleaning and lightly oiling the original gears didn't get me anywhere. By the time I'm done fabricating the hands and mounting it securely I would have probably been better off with the $86 here:
http://members.aol.com/zclock4u/wp.html
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41517
Is your clock not working?
Mine wasn't either. I pulled it out, removed the motor from the mechinism connected it to a battery to test if the motor still worked. It did. Then I lubricated the spindles with light grade oil, like the stuff that comes with sewing machines (Thanks Mum), put it back together and it's worked ever since.
I left it connected to a battery for a couple of weeks so i could adjust the screw in the back fro accuracy.
Mr C
If its broke, try fixing it first.
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41518
Originally posted by mjyikes
Has anyone had good luck replacing the clock from a 72 Z with a clock from a newer vehicle or an aftermarket source ?
I bought a clock on eBay that was a 240Z clock housing and clock hands and face, with a Quartz 280Z clock mechanism installed behind the clock face. Keeps time like a champ and looks exactly like it should for a 240Z. Got it for under $40 to boot!
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41520
As Mike described, I bought the quartz converted clock, sold by MSA, built by this ZClock4U fellow. It appears to be a quality product. The AA battery will last over a year. it has a long lead attached to the battery holder, so you can position the battery down by the fuse panel for easy access.
I sure like knowing what time it is! But, even more obsessive, I can't stand for inoperative functions in my Z! Everything Must Work!
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41553
Interesting. I figured the "professional" quartz upgrade wouldn't use a AA battery. I bought a cheap mechanism at a crafts store for about $5. I think just about every battery-powered wall clock you buy these days uses this same mechanism. I was planning on figuring out how to use a transformer to run it off of the regular 12V clock circuit. The only tricky part will be to get the regular Z clock push-and-twist clock adjustment hooked up. I may even be able to have a seconds hand.
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41576
Hi Mike:
Yeah, that's what I thought. So I didn't go that route. $86 seemed a bit more than I thought a battery powered quartz clock was worth. I got a 280Z Quartz movement that was installed into the 240Z housing using the face and hands of the 240Z (Jeco) clock, so it looks completely normal from a 240Z perspective. Keeps perfect time too! :D
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41578
Where did you get your caps?
Originally posted by germanz
Hi friends,
mine was not working too,oil didn't help.
But replacing the capacitors on the print solve the problem.
They were too old and weak. It will cost you 1 $.
After this you must recalibrate the time with a external supply.
Good luck
Rainer
https://www.classiczcars.com/topic/6721-clock-replacement/#findComment-41765
