I am curious how you made sure the welded nuts on the front of the rockers aligned with the mounting holes at the rear of the front fenders?  If those nuts don't align with the holes on the fenders properly, the fenders might not align with the rest of the car.  In my case, the body shop didn't align them properly.   Now the lower fenders stick out much further than the front of the lower part of the doors.  Now I get to start over with another body shop and fresh paint.  😞
Well so far I've only knocked out the driver's side and haven't tried fitment of that front left fender yet.  But that is a good point and I will check into that.  For my car, that area of the rocker was completely rotted away so there wasn't anything mechanically holding it on (I used magnets).  That and the tab on the fender itself had also rusted off.  So I figure it can only be better in my case lol.  On the passenger side we will have to be more careful.  I'll try and get a picture when I check fitment for the driver's side fender..
Alrighty here are a couple shots of the bottom of the Driver's side fender and the rockers.  When lining them up, the Klassicfab panels include every detail of the originals as far as I could tell, so we were able to use the profile of the bottom of the A-pillar to line up the inner+outer rocker combo pretty easily.
Lining up the rockers:
Shot of the bottom of the new rockers+front quarter panel.  Toe box is still a work in progress; previous repair job basically patched that whole area with a much less concave section, so its getting remade.
Shot of the door+quarter panel alignment.  Door can probably stand to be adjusted forward a bit more here.. but so far so good!:
11 minutes ago, Namerow said:
Great progress.  It's always nice to have a talented welder in the family!
Can you comment on how you removed the old sheet metal?  Did you drill out spot welds?  Metal saw?  Angle grinder?  All of the above?
Very much all of the above.  Sawzall where we could because its quickest/safest.  Drilled spot welds, then followed with hammer and chisel where trying to preserve the old stuff.  Angle grinder with a cutting wheel where we had to.  Dirty work, but it goes a lot faster after you get your methods down..
  • Agree 1
  • 3 weeks later...
  • Who's Online   2 Members, 0 Anonymous, 1,321 Guests (See full list)
