I am restoring a 72 240 and I want to rebuild the steering rack.. Boots are torn, grease and gunk all over it, play, etc. I noticed I can get a rebuilt rack from a big box store for about $550.  Seal kit plus tie rods looks to be around 450 to 500 and I would have to rebuild it.
Wondering if anyone has had any experience with a Cardone rebuilt rack?  I would check it to make sure it is the same ratio. Thanks.
https://www.classiczcars.com/topic/67510-72-steering-rack-rebuild/
FWIW, I just found a closeout on Rock auto. Moog (made in Japan) inner tie rods for $13 each with boots! I also got two sets of outer tie rod ends, as I am pretty certain that the inners will have the same threads on both sides. Looks like I am going to rebuild route.
