SteveJ Posted August 28, 2023 Share #169 Posted August 28, 2023 Looks good. Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-656375 Share on other sites More sharing options...
grannyknot Posted August 28, 2023 Share #170 Posted August 28, 2023 Making a full harness from scratch is a big undertaking, it looks solid, professional. I've used the Tessa tape on a couple projects, it looks great, is good protection for the wires but awful to remove if you screwed up. Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-656376 Share on other sites More sharing options...
Matthew Abate Posted August 28, 2023 Author Share #171 Posted August 28, 2023 (edited) 13 minutes ago, SteveJ said: Looks good. Let’s hope it works! 🤪 11 minutes ago, grannyknot said: Making a full harness from scratch is a big undertaking, it looks solid, professional. I've used the Tessa tape on a couple projects, it looks great, is good protection for the wires but awful to remove if you screwed up. Thanks! Yeah, I discovered that a couple of times. It also can’t be restuck. Once you pull it off it’s shot. By the way, @SteveJ, I found that it’s possible to lessen the effectiveness of the plastic that catches the tab on the 1/4” connectors, so be careful when you pull off those colored connectors. I had to fix a few spots, particularly where a 12 or 10 gauge wire had been removed. Edited August 28, 2023 by Matthew Abate 2 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-656377 Share on other sites More sharing options...
Popular Post Matthew Abate Posted October 22, 2023 Author Popular Post Share #172 Posted October 22, 2023 (edited) Been a minute, so here’s a progress report: I didn’t take any in progress shots of the body harness as I wrapped it, but here’s the final product, coiled up. One thing I found was that if I wrap the whole thing tightly with string it’s a lot easier to get everything taped off and wrapped in the Tesa tape. I just did the string in the opposite direction so I could unwrap it a bit at a time as I went around it with the tape. I used a harbor freight fish tape to get it in, so it wasn’t a very tough job. $15. I messed up my measurements for the light and defroster wires somehow, but thankfully they’re about 18” too long, rather than too short, so I can cut them down and redo the terminals. Just need to get another set of 90° 6.3mm terminals for the defroster. Oh! And a 52mm blanking grommet for that hole under the battery. Edited October 22, 2023 by Matthew Abate 5 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-658392 Share on other sites More sharing options...
Matthew Abate Posted October 31, 2023 Author Share #173 Posted October 31, 2023 Can anyone point me to a place where I can buy the female partner to this male plug on the fuel pump? Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-658866 Share on other sites More sharing options...
SteveJ Posted October 31, 2023 Share #174 Posted October 31, 2023 Eastern Beaver Here: https://www.hi-1000ec.com/product/1139 I have used both places. 2 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-658868 Share on other sites More sharing options...
Xylemer Posted December 7, 2023 Share #175 Posted December 7, 2023 Just want to say a quick thank you everyone that contributed to this post. @Matthew Abate This is going to make my wiring project go so much smoother. I have been searching high and low for this information. There is just so much missing and incorrect information out there. Having everything in one place and documented with such detail is a lifesaver. The Z community Rocks! 2 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-660005 Share on other sites More sharing options...
Matthew Abate Posted December 7, 2023 Author Share #176 Posted December 7, 2023 Haha! Thanks. Note that there are some errors in those older spread sheets. Make sure you triple check everything as you go! I’ll post the latest info when I can. Dashboard wiring should start next month. 1 1 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-660006 Share on other sites More sharing options...
Xylemer Posted January 13, 2024 Share #177 Posted January 13, 2024 @Matthew Abate I too am going through my entire harness, but not to the same extent as you. I'm not replacing all the wire. Not that it's a bad idea, just not in my budget. I will be making repairs and modifications to support fuel Injection since I am going back with a RB instead of the L series. I am working with a fairly low mileage Z. I do plan to clean all terminals with Deoxit when it goes back together to ensure good connections. You mentioned adding an additional fuse in one of the previous post. I thought I might share my current project. I have a fuse box I pulled from a S14. I plan to install in the same location as the original fuse box. I want the dash harness to remain as close to stock, so I'll wire it up with the original connectors. Ideally it's basically plug in play with addition of relays and extra fuse circuits. There may be better aftermarket fuse box option, such as the Bussmann. This didn't cost me anything and has lead to me having a much better understanding of fuse box and wiring in the car. Your work here has also helped pave the way. Hopefully everything works out. This S14 fuse box should be an upgrade from the outdated stock fuse box and offer plenty of expansion for in fuel Injection setup. 3 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-661006 Share on other sites More sharing options...
Matthew Abate Posted January 13, 2024 Author Share #178 Posted January 13, 2024 Pretty cool! I’m surprised how well that fits so far. Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-661008 Share on other sites More sharing options...
Matthew Abate Posted February 24, 2024 Author Share #179 Posted February 24, 2024 @SteveJ, I'm working on my dash harness and want to check with you to make sure I am wiring up this headlight relay correctly. Is it okay to run those to wires from the headlights straight to ground? Also, I could run a wire directly from the alternator to the B terminal instead of coming off the fuse box stud, right? Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-662420 Share on other sites More sharing options...
SteveJ Posted February 25, 2024 Share #180 Posted February 25, 2024 It took me a few minutes to reconcile things since you are only showing one part of the circuit. Yes, that looks correct to me. Since you have pulled the ammeter out, yes, you could pull the power for the B terminal from the B terminal on the alternator. I suggest putting a 10A inline fuse into the circuit near the alternator to protect the wiring if that's the direction you go. 1 Link to comment https://www.classiczcars.com/topic/67523-1973-240z-custom-wiring-from-scratch/?page=15#findComment-662421 Share on other sites More sharing options...
