I have a 75-280 w/91K on it. Got it 2 months ago from So.
California. Have spent time getting it tuned,timed,etc and it
runs real good.
But has developed oil smoking real bad on a long decelaration
mode like coasting down a hill.
Have done compression check twice, range from 150 to 125
or 130 in #'s 4 and 6. Vacuum is 16"/HG .
I adjusted the valves(1st time), no noticiable change.
It does not smoke on start up.
So what do you all think?? Valve stem seals or lower end
IE: rings:cry:
https://www.classiczcars.com/topic/6756-deceleration-smoke/
It sounds as though you are sucking oil past your valve guide seals. At 91,000 miles the seals are likely a bit worn. Well, at least it keeps the top end lubed. Seriously, it won't hurt anything but the environment. So quit decelerating.....keep it WFO!!! Keep enjoying your toy......until you must overhaul.
https://www.classiczcars.com/topic/6756-deceleration-smoke/#findComment-41788
Just a thought , is this a manual or a automatic trans. ? Whey you decellerate you are drawing max vacume , check the vacume line from the automatic tranny if you have one. If there is oil in the line the vacume shift diafram is shot and you are burning tranny fluid. Just another possability.
https://www.classiczcars.com/topic/6756-deceleration-smoke/#findComment-41968
  • Who's Online   1 Member, 0 Anonymous, 1,300 Guests (See full list)
