chaseincats Posted August 28, 2022 Share #1 Posted August 28, 2022 Does anyone know the what the amperage is of the EFI relays (the ones in the plastic bracket clip on the battery-side of the relay bracket? This is the fusible link that comes off of the positive terminal of the battery and not the links that are in the 2 pods with the white caps. Link to comment https://www.classiczcars.com/topic/67792-efi-fusible-link-amperage/ Share on other sites More sharing options...
Zed Head Posted August 28, 2022 Share #2 Posted August 28, 2022 1978 has two. They're green. The best guess seems to be 40 amps. 1 Link to comment https://www.classiczcars.com/topic/67792-efi-fusible-link-amperage/#findComment-644627 Share on other sites More sharing options...
chaseincats Posted August 29, 2022 Author Share #3 Posted August 29, 2022 Thanks, wasn't sure if the colors were just for the links in the 2 pods Link to comment https://www.classiczcars.com/topic/67792-efi-fusible-link-amperage/#findComment-644635 Share on other sites More sharing options...
