Series 1 storage covers
Hi Keith, I think it is because of lack of courtesy not of the plastic. It is bothering but every time I open the storage covers , I unscrewed the knob completely out not to pinch the edge of the cover .
I put a washer under the screw , I don’t know this helps something anyway.
Kats
  • Like 4
You are dealing with 50+ year old plastic here that will have gotten more brittle over the years. Consider bonding a thin reinforcement on the underside - one solid strip with a notch to match the factory shape. That plus @kats recommendation for a thin rubber washer under the knob should help hold back breakage.
Edited by jfa.series1
  • Thanks 1
