Batesgar Posted October 10, 2022 Share #1 Posted October 10, 2022 Looking for center caps for my slotted alloy wheels that came with the car when purchased. I’ve seen a lot of talk and ones listed as 240/280z on line, but found these are typically too small. The center cap hole on mine are greater than 3” and seem unique to my 1973 240z. Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/ Share on other sites More sharing options...
siteunseen Posted October 10, 2022 Share #2 Posted October 10, 2022 8 hours ago, Batesgar said: Looking for center caps for my slotted alloy wheels that came with the car when purchased. I’ve seen a lot of talk and ones listed as 240/280z on line, but found these are typically too small. The center cap hole on mine are greater than 3” and seem unique to my 1973 240z. Measurements, a picture of the wheels would help in finding what you're after. Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/#findComment-646257 Share on other sites More sharing options...
zKars Posted October 10, 2022 Share #3 Posted October 10, 2022 https://www.centercapsdirect.com/ Is one choice. Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/#findComment-646259 Share on other sites More sharing options...
Mark Maras Posted October 11, 2022 Share #4 Posted October 11, 2022 The hole in my US slotted alum wheels is 3". They were on my 71. Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/#findComment-646262 Share on other sites More sharing options...
Mark Maras Posted October 11, 2022 Share #5 Posted October 11, 2022 The hole in my US slotted alum wheels is 3". They were on my 71. The caps were attached using 4 sheet metal screws. The holes are 3 5/8" apart center to center. Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/#findComment-646263 Share on other sites More sharing options...
Batesgar Posted October 11, 2022 Author Share #6 Posted October 11, 2022 2 hours ago, siteunseen said: Measurements, a picture of the wheels would help in finding what you're after. Here’s a few pics. The one on the right is metal and original. The one on the left is a plastic replacement from a vendor that required cutting to fit. The plastic ones have held up on the rear, but the front ones disintegrated at the bottom I assume from the hub grease. They measure 3 and 1/8 and the original metal ones are a bit shorter. Based on the plastic issue I may look to have the original metal ones replated. Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/#findComment-646266 Share on other sites More sharing options...
Batesgar Posted October 11, 2022 Author Share #7 Posted October 11, 2022 1 hour ago, Mark Maras said: The hole in my US slotted alum wheels is 3". They were on my 71. The caps were attached using 4 sheet metal screws. The holes are 3 5/8" apart center to center. Mine were held in place by the bottom ring. I don’t want to drill holes in the mags to secure the cap. 1 Link to comment https://www.classiczcars.com/topic/67899-alloy-wheel-center-caps/#findComment-646269 Share on other sites More sharing options...
