Nice car.
Interesting to see the engine was change to an L-28, but smog equipment from an L-24 has been retained.
I would recommend Sam's Datsun in Winnetka to have a look at your car.  He's one of the last of the breed mechanics that worked for a Datsun dealership during the period.  He's priced fair and no gimmicks.
https://samsdatsunsfv.wixsite.com/winnetka
Edited by DatsunZGuy
URL added
https://www.classiczcars.com/topic/67911-my-new-240z/#findComment-646436
21 hours ago, DatsunZGuy said:
Nice car.
I ordered some new wheels and should have them in a week. Once they are mounted I’ll take the car into Sam Datsun and have him give the car a complete inspection. Thanks for the recommendation!
https://www.classiczcars.com/topic/67911-my-new-240z/#findComment-646454
Given the engine is not stock and smog exempt due to age, you may want to look into removing the excess emissions plumbing.  It makes for a less cluttered engine bay.
You get bonus points because the old owner fitted a series-one air cleaner housing on your car 👍
https://www.classiczcars.com/topic/67911-my-new-240z/#findComment-646461
Had my car inspected by Sam at Sam's Datsun today. Other than the rear springs the car passed with flying colors. Sometime next week a set of Konig Rewind 16x7 wheels with 215 55R 16 tires will mounted on my car. I need to decide if I need to replace the current springs with inexpensive Eibach's or go all out and spring (no pun) for some coil-cover camber kit. What do you guys think?
https://www.classiczcars.com/topic/67911-my-new-240z/#findComment-646570
I'm glad Sam was able to take a look at your car.  He's a good guy.
As for springs, I am currently running Suspension Techniques, along with KYB struts.  Overall, it lowered my car by about an inch.  Going to coil-overs will provide you with greater adjustment, but might be a bit of overkill unless you plan to track the car.
Below is a good write-up on strut and spring options.
https://www.classiczcars.com/topic/67911-my-new-240z/#findComment-646598
  • Who's Online   2 Members, 0 Anonymous, 1,369 Guests (See full list)
