The speedometer hole is the same as the fill plug so it shouldn't leak out. Maybe a drop or two. When you get the seal and o-ring done leave some clean paper under there overnight to make sure it's stopped leaking. Seems like I had to use a deep well 10mm socket to get the seal all the way down.
  • Agree 1
You meant level, right?  The oil level will only be as high as the bottom of the fill plug unless it's overfilled.  Or warmer than when it was put in.
I remember working on my speedo cable without doing anything special.  Had it in off and on a few times trying to get the cable properly inserted in to both ends after a transmission change.
  • Agree 1
Hi All
Thanks for the input all back together, not leaking thus far but only a couple of miles on the road.
Yes, the transmission swap could be the causing the leak. Swap to a wide ratio 5 speed the pinion gear housing was slotted and turned 180 degrees. Meaning all images of a 4 speed pinon gear housing (hoses the gear and shaft) the hold down plate slot and 10MM bolt are top. The 5 speed slot and hold down plate and 10MM bolt are bottom.
The seller of the trans took an angle grinder and created a slot on the other side of the housing and installed. Assume the housing came off a 4 speed trans and is not a 5 speed housing?
Yes the 4 speed was at 12:00 and the ZX (generalization) was at 6:00. The pinion gear itself is the same for both but the holder was different as you noted.
Cutting a slot was the least expensive way of application. The other option was to buy a new holder. You can still get them from Nissan. At least last I checked.
As long as it doesn't leak you should be fine. No one can really see it with the car on the ground wheel side down. 😁
