Still struggling with car at idle after 8 years
Lowered the mixture in both carbs to 2.5 turns clockwise each one.  Rear carb was adjusted to 3.5 turns clockwise and front carb to 4 turns clockwise. I have set the idle speed to 1000 rpm. Ill try tomorrow and report. This is how the plugs came out before i dialed both carbs to 2.5 turns:
I tried brand new set of bpr5es at 3 turns clockwise each carb. 2.5 was too sluggish for driving and engine not kept idling steady. Just took a spin around the neighborhood as it started to rain. No good results.  Plugs 5, 4 and 2.
Now that you seem to have good spark, you may want to consider backing up to the basics. Valve adjustment, timing, then mixture/balance. Not sure what fuel you have there, but our current 87 octane is garbage. My car runs way better on premium (non ethanol).
Edited by emccallum
  • Agree 2
  • Who's Online   2 Members, 0 Anonymous, 1,433 Guests (See full list)
