Still struggling with car at idle after 8 years
This is the same car and individual. @mike How can someone on the forum be able to change identities which creates confusion. Totally removes history on the vehicle and doesn’t give an opportunity to find a solution since the history is no longer available per the user name. Since we are logging on with an email address how can a username not correlate.
Edited by Yarb
3 hours ago, jonbill said:
You can change your display name here:
https://www.classiczcars.com/settings/username/
Fascinating, didn't know that existed.
So you can rock the boat and then name change to try to start over...
  • Wow 1
  • Sad 1
On 2/3/2025 at 6:13 PM, gundee said:
I sent you a message.
Are you sure you sent that to the right person? 🤣  (just kidding!)
About 8 years ago or so i forgot my username and typed martzedcars (as that is a name i use here in my country for mail) but it should have been the dutchzcarguy and now in one of my topic's about my 280zx is that name still visable.. what i mean to tell is.. it was years ago also possible to use another name.
(Also i remember i read something about changing the username only once, so you have max 2 names.. that went out of the window when i saw "someone" here used a 3th name..  anyway.. things change over time i guess..  Or.. i think it has to do with the fact that he has moved to another country and has now another computer-adress. (IP-adress) and that makes it easy to change name(s)..  )
Edited by dutchzcarguy
I got my electromechanic to check the wiring and it seemed connected all the way around.  This is how it ended and hopefully there is no noise inside the dashboard when driving below 1500 rpms. Anyway im waiting for amazon to send me a new 1.5 pertronix coil and 1.5 ohms ballast resistor so we can eliminate lack of electricity from coil to cyl 4.
3 hours ago, dutchzcarguy said:
Pertronix.. my Favorite Brand... to throw in the bin! (New and old..) But ... just my opinion so carry on..
Okay why dont you recommend solutions and better brands before i make my purchase. Perfect critic!
  • Haha 1
Hahaha, perfect man you are.. in your own topic on page 37 I SAID: THIS :  But your topic is now so damn big you don't know yourself what everybody said!
  On 8/16/2024 at 10:01 PM, siteunseen said:
Will Pertronix ignition make the tach twitchy
I don't know .. but it sure makes ME Twitchy!! 😁  (Yeah i know it's only me that does not like pertronix under the hood! The only place for it is in the BIN!)
But stop with this STUPID Behavior! It's very ANNOYING and it helps NO one!
These guys will help you with your car, they love to help.
.https://forums.hybridz.org/search/?q=petronix&quick=1
We are more original equipment hence the name "CLASSICZCARS"
The coil and ballast resistor won't affect just a single cylinder.  They will affect all of them equally.  If you have a single cylinder problem it won't be fixed with a new coil and resistor.
  • Agree 4
  • Who's Online   2 Members, 0 Anonymous, 1,448 Guests (See full list)
