z3beemer Posted January 7, 2023 Share #1 Posted January 7, 2023 I'm in the process of removing the carbs and intake from my 72 engine and rebuilding and installing the round tops on my 73 240z restoration. (also so removing most all the emissions stuff). I noticed a cooling line that runs from the water outlet housing thru the intakes and back to the coolant return line. I noticed a valve on the exit of the cooling line. Thought maybe it was a check valve. After doing some research I discovered it's a thermostatic valve that shuts off coolant flow once it reaches 150 degrees. Unfortunately, it is broken. Any idea where I can get one or does anyone have one I can buy? I believe the Nissan part number is 14100-E8850 (not 100% sure of the PN) but when I run it, it shows discontinued. Tried most the aftermarket sources but nothing listed. Photo attached (note the threaded part is broke off in the manifold. Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/ Share on other sites More sharing options...
SteveJ Posted January 8, 2023 Share #2 Posted January 8, 2023 Well, you might reach out to @zKarsto see if he has any more. He did 7 years ago according to this thread. To remove the broken piece, you can try heating with mapp gas and using an extractor. Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649063 Share on other sites More sharing options...
zKars Posted January 8, 2023 Share #3 Posted January 8, 2023 Seven years. OMG. Yes I still have some. 1 1 Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649064 Share on other sites More sharing options...
SteveJ Posted January 8, 2023 Share #4 Posted January 8, 2023 17 minutes ago, zKars said: Seven years. OMG. Yes I still have some. The internet doesn't forget. 3 Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649065 Share on other sites More sharing options...
heyitsrama Posted January 8, 2023 Share #5 Posted January 8, 2023 Internet does not forget, and we never throw away parts 😬 4 Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649072 Share on other sites More sharing options...
z3beemer Posted January 9, 2023 Author Share #6 Posted January 9, 2023 ZKars...I need one. Let me know price, payment and shipping arrangements. Regards, Paul Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649105 Share on other sites More sharing options...
z3beemer Posted February 3, 2023 Author Share #7 Posted February 3, 2023 Well zKars was kind enough to send me what he had and I was to get one of them to kind of work, so I'll be installing that one. It never did completely close off but did reduce flow thru the valve. Maybe that's the way it's supposed to work. It took a temperature higher than 175 degrees F to change state, but it is what it is. Hopefully performance won't be too greatly affected. 3 Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649970 Share on other sites More sharing options...
SteveJ Posted February 3, 2023 Share #8 Posted February 3, 2023 Blessed be the parts hoarders for they shall provide the used parts to keep our Zs alive. 3 Link to comment https://www.classiczcars.com/topic/68083-thermostatic-valve-neededany-idea-where-to-get-one/#findComment-649971 Share on other sites More sharing options...
