AK260 Posted January 10, 2023 Share #1 Posted January 10, 2023 Hello from across the pond. Someone in the UK forum asked the question: is the 280z auto trans the same as one in the 240z? Given the years and myriad differences between the models I can’t imagine that to be the case. I can well imagine internal differences like ratios etc but what of physical dimensions?The 280z wasn’t for the UK market and we are “mostly” a manual loving nation - so the question may be better answered here with greater experience. Why am I asking? Pure curiosity and for the learning / building my own knowledge bank! Anyone replaced a 240z auto ‘box with a 280 one and has any thoughts /advice / or even a write up on this? I can’t seem to find anything on Google! It keeps pointing me to swapping out an auto for an MT. Thanks in advance and apologies if it’s a dumb question written with blurry eyes while having insomnia! 1 Link to comment https://www.classiczcars.com/topic/68087-is-the-280z-auto-transmission-the-same-as-the-one-in-a-240z/ Share on other sites More sharing options...
SteveJ Posted January 10, 2023 Share #2 Posted January 10, 2023 I'm definitely not an expert on the subject, but according to https://www.carpartsmanual.com/datsun/Z-1969-1978/power-train/transmission-assembly there are four part numbers for automatic transmissions. Of course, the gear ratios can be found in the FSMs on this site. The 73 FSM was the first that I found with AT section in the FSM. The rear end ratio is the same across all years. I can't think of a reason why there would be external dimension differences that would adversely affect installation. As for tips/tricks advice, I know I have seen a thread here or there on swapping in an automatic either on this site or zcar.com. The only recommendation I can make is to modify the wiring to the solenoid to add the neutral safety switch. 1 Link to comment https://www.classiczcars.com/topic/68087-is-the-280z-auto-transmission-the-same-as-the-one-in-a-240z/#findComment-649160 Share on other sites More sharing options...
AK260 Posted January 10, 2023 Author Share #3 Posted January 10, 2023 Thank you Steve! Much appreciated chap. Link to comment https://www.classiczcars.com/topic/68087-is-the-280z-auto-transmission-the-same-as-the-one-in-a-240z/#findComment-649167 Share on other sites More sharing options...
SteveJ Posted January 10, 2023 Share #4 Posted January 10, 2023 21 minutes ago, AK260 said: Thank you Steve! Much appreciated chap. No problem. One thing I forgot to mention is that the gear ratios of the transmissions are in their respective FSMs. I'm working in the office today so I don't have ready access to my copies at the moment. Link to comment https://www.classiczcars.com/topic/68087-is-the-280z-auto-transmission-the-same-as-the-one-in-a-240z/#findComment-649169 Share on other sites More sharing options...
