Yes! That valence makes all the difference in the world when you get up in the MPHs. You saw that it is adjustable too so you can get it up close and snug with the spoiler.
The two 10mm below the side marker lights were my biggest pain.
  • 1 year later...
Got the new Datsun & 280Z emblems today (from resurrected classics). I contemplate the location of the Datsun emblem a bit, since on the hatch, it is set on a diagonal - it's obviously not really intended to be set in a horizontal spot. I ended up angling it very slightly to mimic the hatch fitting
280Z set horizontally, 15mm up from bottom edge
I just drilled the spoiler slightly under the pin size, so it's a press fit
27 minutes ago, SteveJ said:
There are little retaining clips you can put on the pins of the emblems to help hold them in place.
Hello Steve - I have them - they come with the new emblems - the spoiler is thicker than sheet metal, so I don't k now if the clips will lock into place. I didn't want to risk drilling what would then be an oversize hole in the spoiler & have the clip not work as intended.
  • Like 3
