Site going down soon for upgrades ×
Not sure a leakdown test would show the source of the oil.  It shows whether the rings or the valve seats are sealing well, holding pressure in the combustion area.
The valve seals were apparently just eyeballed.  A borescope might still show something.  Oil soaked intake valves, versus clean ones.  The oil from the crankcase must come through the intake system or past the rings.
Or just pulling the intake manifold.  Or the head.  Pulling the engine is pretty easy though.
On the rings - he implied that he got the rings from a suspect vendor.  So it's an issue of ring quality or type or labeling.  All of them.  Seems like the builder would have noticed but who knows.  But for some reason emccallum had the boxes.  Not sure how the rings got on the pistons.
It would definitely indicate if the rings are the issue, I've specifically diagnosed an issue with oil consumption on my K24 that way. One bad oil control ring. It was consuming a quart every 200 miles. True that if the valves are fully seating, it's not going to indicate if the valve seals are the issue. As you said, either removing the intake or carbs & looking into the ports for oil on the valve stems would likely be the way to go for that aspect.
On 4/25/2023 at 2:09 AM, emccallum said:
Good points. PCV is clear, and oil was 5qts and to the full mark.
Like a dumb*ss I threw away the old rings and boxes, so I dont know what they were.  I bought rings, rod/crank bearings. No pistons or head stuff.
Spoke the the engine guy at length today. He did some homework on the SU's and asked me to check the fuel pressure. 2psi. He said pull the motor.
I checked the dipstick for any fuel and noticed its about a qt low. I think the missing quart is all over my shop and concrete! I will post up what I find. May pull it on Friday if I can find a spotter.
Bad video attached.Enjoy my pain 🙂
Let some good shop do the engine !, and rebuild the head also properly, horrendous valve clatter ! A proper shop will replace these and polisch the cam, or replace the cam, this will stop the rattle with proper valve adjustement.:
Datsun 240Z 260Z 280Z ZX 1970-83 L24 L26 L28 Valve Cam Rocker Arm | eBay
My L24 is silent, no rattle can,  it's a common myth L series rattle, but that's BS
WOW.. what a noise that thing makes, what was the rpm in the video?  2000, last seconds going to 3000 rpm? Does not sound very nice! Sounds more like you had a box of cutlery on top of a very shaky engine!  sigh 🙊
  • Haha 1
