Left and right turn signal light not working no flash no click. Any clue?
That same unit will also work for your hazard lights. That flasher can is mounted at the top of the passenge side kick panel. I switched out to these units years ago and love the performance improvement, all with incandescent bulbs.
39 minutes ago, Namerow said:
'Performance improvement'?  Please explain.
The OE cans are "thermal" - they use a bi-metal strip that heats and cools at differing rates depending on the flow of the electrical current.  They usually operate more slowly at idle and then speed up as engine revs increase. The newer units are termed electro-mechanical, operate at a constant rate independent of the engine speed.
26 minutes ago, jalexquijano said:
I believe the original relays were metal cans. Am i right?
Correct, the OE flashers are usually a aluminum can. They typically have a metal tab for a small screw to mount to a surface. The new ones usually have a plastic case, no mounting tab. You can glue a tab to the case for the mounting screw.
  • Who's Online   1 Member, 0 Anonymous, 1,232 Guests (See full list)
