Posted
Higuys,
Is there a chart or a graphic of the connectors nears near the firewall (blue, white and black) that show the connector names?   I need to know which is connector "C-4" which has the wires for the headlamps, so I can clean the pins and improve the leadlights.  I looked in the Body Electrical section in the FSM and it only refers to C-4, and even tells you where the specific pin is for power & ground connections, but doesn't tell you where to find the connector itself.
While I'm looking at them, I will mark them with a black marker.
Thx
Edited by TomoHawk
https://www.classiczcars.com/forums/topic/68372-firewall-connectors-diagram/
