Well, that was fast. The connecters arrived a little while ago, and I have put them in a divided storage container so they will be ready to use.
If you need YPC connectors, hi-1000ec.com is legitimate.
I purchased extra male 3-pin and 6-pin waterproof connectors. The 3-pin is for wiring a conventional Bosch relay for the AC relay. The 6-pin is for jumpering out the voltage regulator connectors in 75-77 280Zs when converting them to internally regulated alternators.
I bought connectors that could be used for the center gauges, too. It could also come in handy for a conversion to Speedhut gauges.
  • Like 3
https://www.classiczcars.com/topic/68453-ypc-connectors/#findComment-655293
