swflaz Posted July 21, 2023 Share #1 Posted July 21, 2023 My 1972 (11/71) 240Z is in the garage for engine work. The shifter has been in the neutral position all that time. Now that it's ready to be test driven we find that the shifter is hung up and will not engage first or second gear but only third and fourth. On an important side note, the car was two miles inland during hurricane Ian and flood water came up about 18 inches on the sides of the car. Don't know whether water may have found a way in. Thoughts please. Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/ Share on other sites More sharing options...
Patcon Posted July 21, 2023 Share #2 Posted July 21, 2023 18 inches might be enough to get into the transmission. I'm not sure you're gonna be able to sort this without removing the rear transmission case Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655265 Share on other sites More sharing options...
dutchzcarguy Posted July 21, 2023 Share #3 Posted July 21, 2023 11 hours ago, swflaz said: Thoughts please I would take the car for a spin in the reverse gear (i guess that one works aswell) , maybe drive a bit in 3rd.. when it heats up the gears will/can come available again (first and second.) But do check first the gearbox oil for water, first open the filler and then the lower one to let some oil/water out.. if there is any water inthere.. replace the oil. then go for a small ride to let oil go round in the box. Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655271 Share on other sites More sharing options...
swflaz Posted July 21, 2023 Author Share #4 Posted July 21, 2023 Thanks for the suggestions I'll be trying those out today. I'll post any results. 2 Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655274 Share on other sites More sharing options...
swflaz Posted July 22, 2023 Author Share #5 Posted July 22, 2023 Thanks Patcon and dutchzcarguy. Trying unsuccessfully to get a couple of clarifying pics up. found no water in the tranny and added new lube. however, the barrel shaped piece that the shifter fastens to was seized up. probably from water intrusion over a few months time. it moved fore and aft in first and second but not to the side to get to third and forth or reverse. managed to loosen it some with PB blaster and equivalent and some prying/light hammering. moving it backward in an attempt to get it off and clean up. Have moved it rearward about an inch so far. Continuing in the A.M. 1 Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655310 Share on other sites More sharing options...
swflaz Posted July 22, 2023 Author Share #6 Posted July 22, 2023 P.S. have also got it to move to the right enough to engage third and fourth gear but not reverse yet. Just very very stiff. 2 Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655311 Share on other sites More sharing options...
swflaz Posted August 3, 2023 Author Share #7 Posted August 3, 2023 Problem solved. apparently the cause was water intrusion during the above mentioned storm which eventually seized up the shifter. Continual lubrication and gentle tapping finally freed up the shifter so now i can access four gears and reverse. Now on to the next challenge. thanks for your comments and suggestions. 1 Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655618 Share on other sites More sharing options...
Yarb Posted August 3, 2023 Share #8 Posted August 3, 2023 Did you ever drain the gear box? Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655621 Share on other sites More sharing options...
swflaz Posted August 4, 2023 Author Share #9 Posted August 4, 2023 Hi Yarb, yes the transmission has been drained and refilled. No water, thank goodness. Next project is getting the interior back together. Thanks for the comment. 1 Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655660 Share on other sites More sharing options...
Yarb Posted August 4, 2023 Share #10 Posted August 4, 2023 That’s good news Link to comment https://www.classiczcars.com/topic/68457-stuck-transmission-shifter/#findComment-655662 Share on other sites More sharing options...
