Lean times, and not just because of high prices and low wages.
Ok, I'm having a bad week with nice stock L24 with SU's.  Runs fantastic until you get over 4-4.5K RPM, then it leans out and misfires.
Facts and Observations
  • SM needles (been trying several others....)
  • Four screw early carbs. Fresh and minty.
  • New AEM AFR gauge in the exhaust. Never leave home without it.  AFR's 13-14 around town below 4K RPM, car pulls like crazy super smooth 800 RPM smooth idle, but crawls up to 15-16.5 or higher and misfires when you get over 4K. Doesn't fall on its face, just gets rough running and power falls off and has trouble getting to 6k RPM.
  • Fuel deliverability confirmed. NOS stock pump and then with an NOS electric pump (mechanical out of the circuit), both behave the same way. Both produce buckets full of fuel when I free flow them into, well, a bucket.
  • Float level confirmed. Was a tad low, now perfect. No change in behavior before or after.
  • yes there is oil in the domes.
  • If I pull the chokes on and get the jet tubes down 1/8 then it runs better and the AFR's stay near 15, but turning the mix screws down to 5 or 6 turns to get that same result makes the idle-4K range pig rich and awful. No surprise there. Not a solution.
  • Tried another set of SM needles, (these dang things are typically too rich on a stock L24!!! Not this time) same thing.
  • Valve adjust and vacuum are normal.
  • NGK BPR^ES usual at 0.036.  All 6 look identical and lean-ish after a few hard pulls.
I'm about to start sanding down the lower half of a set of SM needles to try to get it richer up top. Not easy to tell where to start sanding.
Suggestions? What am I missing?!?!?!?!?
Edited by zKars
6 hours ago, zKars said:
So what did we learn today?
-Misfires can cause a lean condition as read on the AFR gauge, just like the reverse.
-Change a bunch of stuff and get the same result? You are changing the wrong stuff.
-Tunnel vision is blinding.
Love the mission summary.
I've heard it put this way... Misfires leave oxygen in the exhaust stream. AFR pics that up and interprets it as "lean".
  • Like 4
  • Who's Online   2 Members, 0 Anonymous, 1,111 Guests (See full list)
