Never before heard valve knocking started yesterday...
It was a single pinging/knocking that sped up when revving, and it occasionally was a louder knock like something was loose, so I immediately shut it down. This all happened while under the garage at cold startup.
I've taken off the valve cover and don't know where to start to diagnose.
Here are pics. Any help on what is the most likely culprit and path to diagnose is much appreciated. Thanks.
If, by pulley, you mean that off-center cam-looking thing in the middle of the chain sprocket, that's the fuel pump eccentric.  It is supposed to be off center, it pushes the fuel pump lever each time it passes by.
Can't tell how many RPM "revving' is or what ping or knocking actually mean.  But I can say that your valve lash seems tight.  On a properly adjusted valve train the base circle (the part of the cam lobe with no hump) will not be worn since that is where the lash is, and the anti-rattle springs keep the wear pad off of the base of the lobe.  The base circle is usually brown.  Yours show wear all the way around.  You might want to recheck valve lash.
You might shine a light down toward the chain tensioner and see if you can tell how far out is extended.  You can also set your damper pulley at zero and check your chain wear marks on the sprocket.  The notch and groove.  Make sure the tight side, driver's side, is tight.
Edited by Zed Head
+ not
People here call that the lash pad.  That's not good, it would be holding the valve open.  Any chance the locknut came loose on the adjustment side?  Can you wiggle it by hand?
Was it mine, I'd recheck lash from scratch.
Locknut isn't loose.
I get what you're saying about the base circle wear. I've never adjusted the valve lash, so I'll research it.
But in any case the valve appears to be stuck down (open). How would adjusting the lash help that?
Edited by Dadsun
Sounds like it.  Or somebody adjusted the lash too loose on that valve.  You can compare the height of the valve when it should be closed (on the base circle) to other valves that are closed.  It could be just stuck or it could be stuck because it's bent.
Rocker arms jumping their lash pads is not uncommon when revving an engine that's been sitting.  You can find stories.  Many people just put it back together and carry on and never have it happen again.
I just finished doing this comparison. The stuck valve when compared to fully closed valves is a little low, but not much. Nowhere near as low as ones fully pressed by the cam lobes. So, it looks stuck, but I guess there's a chance it's not bent or damaged the piston. I'm trying to avoid pulling the head because that's out of my expertise, which means getting it towed to a mechanic. Unless I can unstick it. Open to suggestions. I searched old threads and some people try penetrants and/or disassembling the valve.
Not an expert.  But, barely lower is what you'd get if the valve head was bent on the stem.
Since everything is back together it might be worthwhile to pull the spark plugs and spin the engine by hand to see what the valve is doing.  Does it get stuck or does it move freely.  Then, if you're brave, spin it with the starter with the plugs out.  Don't forget to disconnect the coil, or use a remote starter with the key off.
You could also measure cylinder pressures if it spins freely.  If the valve is not closing completely you'll get a zero on that one.
  • Like 3
  • 2 months later...
