HusseinHolland Posted September 3, 2023 Share #1 Posted September 3, 2023 (edited) Whilst I've been adding wiring for my AC install, I've also been wiring the Bosch CIS. It was used on Volvos in the mid 80's with K-JET. V6 version - has correct ECU with 6 cyl ignition pulse. (B) Benzine 2.8l (F) Fuel Injection my wiring Bosch 0280 220 008 - Leerlaufregler = Idle Control combined wiring harnesses for AC & CIS module will be tucked up in right corner removed the throttle body. Made it easier to access the water housing to redrill & add a 12x1.5mm Timesert for the ECT Lots of grease on the drill & tap, picks up the shavings ECT 0280 130 028 (VO 1306024) installed IACV will go something like this. CSV will move to throttle body, where air port is now. CSV port will be used for the IACV return Flange offset/bolt spacing is identical. Edit - Volvo uses an o-ring for the CSV - have to check the port ID in the TB Edited September 27, 2023 by HusseinHolland additional text, typo 1 Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/ Share on other sites More sharing options...
HusseinHolland Posted September 4, 2023 Author Share #2 Posted September 4, 2023 (edited) Coil (-) connection. Red-White, since that's what Volvo uses. Blue is usually (+), glad I checked what Nissan uses for (-) Drilled (9/16") & tapped the intake for 3/8" NPT elbow fitting Made a support plate for the 3517886 IACV. No room for a bolt to come through the plate from above, so I welded a nut on the backside & put in a short stud to retain the IACV bracket. Re-tapped the vacuum port for the charcoal canister to 1/8" NPT & plugged it. The IACV hose passes right over it Moved charcoal canister vacuum port to rear of plenum, using quick connect with nitrile line With the IACV placement sorted, I wired the 3 pole connection and the 2 pole for the ECT, and the ground connections at the intake CSV placement in TB to get a clean run on the CSV feed hose, I'm going to flip the CSV. Converting to barb fitting. Using a different CSVB than above, I have 3 (Volvo) variants with differing offset connectors Made the block off plate for the B.C.D.D, with 3/8" NPT port for the valve cover vent. Used the B.C.D.D base gasket as the template for the mount holes shaped somewhat, brass elbow fitted. Used HondaBond to seal the plate to TB. B.C.D.D port redrilled to match the greater breather vent ID above, since the above port is now dedicated to only idle control Breather vent elbow fitted below will clear the TPS once reinstalled. Have to figure out a clean way to unify the valve cover port hose with this 78 280Z AAV & Breather vent hose layout for ref. Edited September 4, 2023 by HusseinHolland corrections 1 Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656674 Share on other sites More sharing options...
HusseinHolland Posted September 6, 2023 Author Share #3 Posted September 6, 2023 (edited) Only had about an hour after school today, so I worked fitting the CSV to the TB, and figuring out the VC vent/breather setup to the TB The Volvo CSV uses an o-ring to seat, rather than a gasket, so I countersunk the hole in the TB to 14mm, to allow an injector o-ring to seat snugly in there after that I worked on the vent/breather. I couldn't see a clean way to route the hose the long way around, as the factory layout runs, so I doglegged it & I'm running it down to the inside of the TB, clear of the linkage. EDIT - flame arrester is located inside straight section, not at upper elbow The thing about doing it this way, the #1 exhaust runner is exposed in that area, for whatever reason Nissan didn't make the pretty extensive heat shield come that far forwards. Since I don't want the vent hose to get crispy in the heat, I made a stainless steel additional shield, attached to the factory one. 5" length, about 2.75" deep, with a 3/4" flange adding SS M6 rivnuts fitted now the breather is protected somewhat Edited September 27, 2023 by HusseinHolland add text Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656744 Share on other sites More sharing options...
HusseinHolland Posted September 7, 2023 Author Share #4 Posted September 7, 2023 Minor things after work today. Temps still in the 90's & humid - not pleasant working outside. Made the harness extension for the CSV & bridge harness for the TPS to incorporate the signal wire to the CIS module. Next I'll need to pull the fuel injector rail & replace all the fuel hoses. I spent an hour figuring out if I could fit the Volvo FPR pod on the right side near the filter. Not going to work with the existing layout, the angles are all too acute, it would end up stressing the fittings on the pod itself, which is plastic. I'll have to think a little more about that. The only reason I'm bothering is I'd rather rework that while I have the rail off. Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656783 Share on other sites More sharing options...
HusseinHolland Posted September 8, 2023 Author Share #5 Posted September 8, 2023 We have thunderstorms coming in, so I worked on getting the wiring & fuel hoses done so that nothing is exposed, since I have the hood off. Removed all the fuel hoses. The injector ones were too long - approx 2" - the rail was set such that the FPR was touching the accelerator link arm. Lots of worm clamps 😞 After I replaced the rail hoses with sections of 10mm ID nylon fuel tube I put the rail back in place to measure the injector hose length. I reckoned 1.75" would be more appropriate & not lift the rail Most everything back together, so now I just need to make a TB gasket, bolt the TB back on, wire a couple connections for the AC in the bay, remove & drain the AC compressor, refill with PAG46, then I can move on to all the wiring under the dash, then get the dash back in (eventually). Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656826 Share on other sites More sharing options...
HusseinHolland Posted September 10, 2023 Author Share #6 Posted September 10, 2023 (edited) Looking back at the pic of the 78 bay I took, I realized the plug wires were not properly placed - it irked me that they were hanging out on the right side, so I took care of that & made the TB gasket EDIT - the external throttle return spring had a sleeve of some sort inside it - it was cooked, presumably from the manifold proximity, so I'm not sure of the intent. I removed the scraps & put a section of greased nylon (8mm OD) tubing inside the spring. Edited September 10, 2023 by HusseinHolland 1 Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656885 Share on other sites More sharing options...
EuroDat Posted September 10, 2023 Share #7 Posted September 10, 2023 I havd been following this thread and a little suprised no one has commented yet. It is an interesting mod you're attempting and I hope it delivers the results you are looking for. Great detail and plenty of photos so others can follow. Slowly buy surely these parts (AAR for example) are getting harder to find and a possibld update to later more available parts is more than welcome. 2 Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656898 Share on other sites More sharing options...
HusseinHolland Posted September 11, 2023 Author Share #8 Posted September 11, 2023 On 9/10/2023 at 4:07 PM, EuroDat said: I havd been following this thread and a little suprised no one has commented yet. It is an interesting mod you're attempting and I hope it delivers the results you are looking for. Great detail and plenty of photos so others can follow. Slowly buy surely these parts (AAR for example) are getting harder to find and a possibld update to later more available parts is more than welcome. The thing is, the ECU for this is not readily available, and typically expensive if you can locate one. I'm doing it because I have the components, and my stock AAV is dead anyway. This will all only be used for a year or so, then I'm putting in a 350Z drivetrain 😁 Weather has been terrible here, so not getting much done. Did a little work on the wiring inside the cabin while it was raining harness for transistor relay for switching the stock TPS signal to the CIS module to open at idle, ground off idle. yellow wire is the signal from the TPS, so it needs to go to the relay first, then the switched leg goes back to the module it will be situated alongside the module. I will need to sleeve the relay 1 Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-656951 Share on other sites More sharing options...
HusseinHolland Posted September 23, 2023 Author Share #9 Posted September 23, 2023 (edited) Ran the engine today, dash frame with harness in place to check systems there is a problem with the idle control - idle rpm is way too high for any modulation. Pretty sure there is a passage from the plenum side of the TB back through to the intake via the passages used for the factory BCDD system - openings in bottom area. I thought they were closed off, but too much air is bypassing the idle valve circuit. Pic from when I installed the TB - need to remove it & check the passageways Edited September 24, 2023 by HusseinHolland add pic, typo Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-657396 Share on other sites More sharing options...
Captain Obvious Posted September 23, 2023 Share #10 Posted September 23, 2023 32 minutes ago, HusseinHolland said: Pretty sure there is a passage from the plenum side of the TB back through to the intake via the passages used for the factory BCCD system Sorry, I wasn't paying enough attention. On the 280, you can't just slap a plate on the bottom to block off the BCDD. If you do that, you'll have a huge passageway around your throttle plate: 1 Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-657397 Share on other sites More sharing options...
Captain Obvious Posted September 23, 2023 Share #11 Posted September 23, 2023 You can get away with that on the ZX because of the different BCDD design, but on the 280Z, you have to block off at least one of the internal holes. Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-657398 Share on other sites More sharing options...
HusseinHolland Posted September 23, 2023 Author Share #12 Posted September 23, 2023 10 minutes ago, Captain Obvious said: Sorry, I wasn't paying enough attention. On the 280, you can't just slap a plate on the bottom to block off the BCDD. If you do that, you'll have a huge passageway around your throttle plate: There you have it. I'll remove the plate I made & plug the front side port. Thanks CO! Link to comment https://www.classiczcars.com/topic/68540-bosch-volvo-constant-idle-system-instead-of-aav-bcdd/#findComment-657399 Share on other sites More sharing options...
