MSA has one similar if not exact but fiberglass. '70 thru '73. I would bet it's the shorter radiator.
I put a 280 radiator in my '72 with a full shroud off a junkyard ZX. Works great too. I have always wanted the scarce as hen's teeth 240 belly pan. One day I'll find one for a reasonable price.
https://www.thezstore.com/product/5386/radiator-shroud-70-73-240z
I’ll probably get the MSA one. This one is way too much. It’s also pretty different from the factory one. Other than being 3 pieces instead on one, it’s flat on the engine side. I was just curious if anyone had seen this before.
Yes. Good if you have parts to sell, bad if you want them.
I slightly blame MZR and other customizers. There are only so many of the NLA parts that aren’t being reproduced, and I will bet they hoarded stocked up on them.
Edited by Matthew Abate
  • Agree 1
  • Who's Online   0 Members, 0 Anonymous, 1,572 Guests (See full list)
