Parking/Tail lights fuse holder heating up
1 hour ago, SteveJ said:
My complete list:
Here is my current list of recommended LED bulbs:
White LED (license plate and reverse lights)       https://www.amazon.com/gp/product/B08XWWJ4N4
Amber LED (front side markers)       https://www.amazon.com/gp/product/B08XWXXPN5
Red LED (rear side markers)       https://www.amazon.com/gp/product/B08XWX81ZD
Red 1157 LED (rear turn signals and brake lights)     https://www.amazon.com/gp/product/B08H4MXQMZ
Amber 1157 LED (front turn signals)     https://www.amazon.com/gp/product/B08CZ7N9TD
Green LED (gauge lights)       https://www.amazon.com/dp/B092VNXS6H
Red 1156 LED (rear lights)       https://www.amazon.com/gp/product/B00WGAUIR2
Gauge Lights:
Green LED (gauges and turn signals)   https://www.amazon.com/gp/product/B0B9MGSX7K
High beam LED               https://www.amazon.com/gp/product/B08GS325N6
Brake idiot light           https://www.amazon.com/gp/product/B08GRJGD5Y
Flasher Relays (2)       https://www.amazon.com/gp/product/B0811GTVH2
Hella H4 housings:       https://www.amazon.com/dp/B001G76Q2W
or
Koito H4 housings:       https://parts.toyotasouth.com/oem-parts/toyota-headlamp-assembly-8111060p70
Auxito H4 LED bulbs:       https://www.amazon.com/gp/product/B07TQLK6SH
Beautiful, I love the adjustable flasher unit.
3 hours ago, SteveJ said:
My complete list:
Gauge Lights:
or
I think that should be in the resource section or maybe a searchable thread of its own
  • Agree 1
  • Thanks 1
16 hours ago, Zed Head said:
I restaked it with a punch and it came back to life.
Normally i would have said that, but these fuseboxes are to old for that. the plasic will brake.. you need to be very careful.
clean contacts and LED lights are the solution. And a look with a infrared thermometer after 15 min. of "everything ON" over the fusebox and wireing is a good test!
For cleaning the contacts where the fuses go, look for small bore cleaning brushes. I like the ones with the 1/4 hex end for using with a drill or hex screwdriver handle. https://www.amazon.com/Variety-Stainless-Twisted-Cleaning-Corrosion/dp/B09P5237JH
Make sure you have the negative of the battery disconnected before attempting this.
  • Agree 1
36 minutes ago, SteveJ said:
The only thing is that this will change periodically from vendors changing their offerings.
I considered that and agree, but you could also add enough identifiers like 1156 amber or max length to make it possible to search if an offering become unavailable
My complete list:
Gauge Lights:
or
Great list!!
I used the same green LEDs for the gauges and found the see through front was creating bright / hotspots on the gauges and had to rough it up with some 800 grit for better light dispersion.
Did you find the same issue?
