Following SteveJ's suggestion I've been converting all the external bulbs to LED. I found in the process that my reverse light circuit was dead - no continuity through the reverse light switch on the trans. Checked when I was changing the gear oil.
New switch in place. One of the Datsun guys on the Old Volvo forum said these switches tend to not last.
Since I had the under dash open again for the HEI module swap out, I cut the R/blk feed from the switch to the rear & fed that into a relay as the trigger signal (86). Switched power to the relay is the R/gy wire, 2nd from the right. No fuse in the pic yet. Output from the relay (87) then connected to the R/blk going to the rear lights. Used 6.3mm spades for the harness connections, M/F, so I can bypass the relay if needed for any reason. Maybe it's not as likely to fail with lower draw LEDs anyway.
Edited by HusseinHolland
https://www.classiczcars.com/topic/68651-reverse-light-circuit/
