4/75 Datsun 280Z; Leaf Green, CA market, 250K miles, Long Term Project 03/2023-
13 hours ago, Yarb said:
I chose the Trophy because that’s what you deserve for being an educator friend. Congratulations Sir!
Second that.  Not an easy job:  1/3 educator, 1/3 keeper-of-order, 1/3 entertainer.  Made all the more challenging in this modern era of cell phone and texting distractions.
  • Agree 2
16 hours ago, psdenno said:
Congratulations on finishing your teaching career.  I retired from teaching 14 years ago and every June I like to watch this video.
Lol - my co-workers were singing that to me - emphasis on "Schools Out Forever" 😁
  • Agree 1
Getting the truck ready for another Ithaca trip, and a short one to Kingston, NY tomorrow  - I got a new windshield installed today - the old original one was so pitted driving at night was a nightnmare
temp-Imagetsfb-Yi.avif
New wheels & 2 new Bridgestone Potenza T005's for the C30 came - so I got those mounted. Need to check the toe
old one
new
temp-Imagesir-QKZ.avif
This is what I drove home on last Sunday
temp-Image-Ncrt-TG.avif
On 6/26/2024 at 8:16 PM, HusseinHolland said:
Today was the last day of my teaching career. I'm officially retired 🤪
Got a little wiring on the south wall - finished up the wiring of the 240 & 120 receptacles
Used crimp eyelets for the grounds
wired each receptacle separately rather than bridging them
12AWG for the 20A receptacles
Made sure they were the right version 240V outlet this time
10AWG for the 240V
10WGA Junction that feeds the East center post receptacle
Broke down & bought an OEM fuel sender from ZcarDepot - I've gone through two different aftermarket senders, and both leaked around the sender pins. Installed it today
Hopefully the end of my gas smells
Edited by HusseinHolland
typo
While I'm in wait mode for the TUS-11a Ujoint, I cleaned up the floors & undersills where the undercoat was either non existent or damaged, and primed exposed areas, then stone chip protection then undercoat. Have to wear a coat & respirator  - this stuff is nasty. The ambient temps are in the 90's, so I think I lost about 5lbs in water weight by the time I was done.
Area that was beaten to fit the 350Z seat
wire-brushed the original undercoat & soaked with some turps to soften up the old stuff. Chipped off the loose bits.
Replacement (warranty) tension rod bushings came, so I pout those in also
Still waiting for Datsun parts. So, I started fixing the rust on the Volvo pickup right rocker panel. Driver's side has no issues.
Pretty bad. It was bad when I got the wagon 3 years ago
started poking from the inside
have to fix the inner structure before I can replace the rocker skin. This mid section below the captive nut is the reinforcement for the B pillar,PXL_20240710_161708024.jpg
Scraped all this sealant/undercoat back from the floor to rocker lip, to make sure nothing will catch fire when I start welding in new sectionsPXL_20240710_180408863.jpg
  • Like 4
Scraping away at the underside where I will need to make a cutPXL_20240711_142906527.jpg
Shoulder gets wider towards the rear. It's been very hot & humid making it difficult to work outsidePXL_20240711_143007349.jpg
Cross section of rocker/sill/B pillar reinforcement  cut from a wreckPXL_20240711_131327914.jpg
Drilled out the sill welds on the spare section - I want to try & cut the inner repair piece from thisPXL_20240711_153330924.jpg
Cut some sheet metal in preparation for bending Have to match the rocker section, and make some inner support sectionsPXL_20240711_185606163.jpg
Also put new handles on two sledge hammers I dug out of the yard many years back. Now I have 4 sizes - these two fall in the middlePXL_20240711_193357607.jpg
Your place was a hammer farm back in the old days?
  • Haha 3
I dunno - I also found a large amount of horseshoes, railroad tie nails and a pair of gas filing station 'guns' from the days before the vent caps were required. Not sure what all that was about.
  • Who's Online   1 Member, 0 Anonymous, 1,226 Guests (See full list)
