4/75 Datsun 280Z; Leaf Green, CA market, 250K miles, Long Term Project 03/2023-
  • 5 weeks later...
Finally resolved the exhaust fumes in car issue - I added the downturn tailpipe (2.5" SS ) I found either on here on another Z forum, I forget. Drove it around to determine if it worked - it did - so I tacked it in place
Didn't care for the look of the single tip, so I added a fake next to it, staggered slightly
Much happier driving around now, can have both windows open! 😀
Edited by HusseinHolland
  • Like 3
  • 1 month later...
Took the Z out for a drive yesterday - it was warm enough, and no salt on the roads yet. C30 is out of commission with a broken clutch master cylinder link rod.
Steering column, instrument cluster, all have to come out to access the pedal aassembly
I have the pedal assembly out. I drilled out & tapped to M6x1 the fixed pedal pivot so it came be serviced without quite so much drama
Back on the C30 - New clutch master arrived yesterday - normally only takes 2 days via USPS from CT, this one took over a week. Anyway, the weather has not been conducive to working outside, either way too cold or snowing. Today it was sunny & 34º, so I took advantage of that to put the car back together
Sold under Sachs brand - unit is the same manufacturer as originally installed - FTE - just with metal rod instead of the plastic mine hadpxl_20241227_172521406-jpg.93172
pxl_20241227_172525851-jpg.93173
test fit in painted bracket
pxl_20241227_172958488-jpg.93174
So, the bracket & MC cannot be installed as one, even without the pedal in play. I had to insert the MC in the firewall opening first, then position the pedal bracket, then set/lock the MC in the bracket.
Left side mount points are tricky to accesspxl_20241227_181149817-jpg.93176
Pedal set in bracket
pxl_20241227_182636457-jpg.93177
Link rod bushing set into pedal
pxl_20241227_182645676-jpg.93178
With that located, I attached the hydraulic line, feed tube & switch connector
pxl_20241227_180220408-jpg.93175
Immobilizer switch harness routed
pxl_20241227_200935693-jpg.93183
Over-center mechanism  in place - I used a tie wrap to hold the spring compressed, then set the mechanism & cut the tie wrappxl_20241227_184834395-jpg.93181
pxl_20241227_184828546-jpg.93180
Then I bled the clutch - had to remove the airbox, and the rad hose/engine harness support bracket to access the bleederpxl_20241227_190336128-mp-2-jpg.93186
With the bleeder valve open, I drop the tube into a container of brake fluid & stroke the pedal until there is resistance, checking the fluid level & topping it off after a few strokes.
pxl_20241227_190845666-jpg.93182
After that I re-installed the steering column & shroud, under dash panelling, instrument cluster, surround, steering wheel & airbag.Finally, I forgot to remove the set screw I used to locate the airbag contact reel spring, so I just cut it short. Not going to hurt anything as is.pxl_20241227_212055441-mp-2-jpg.93185
  • 3 weeks later...
Been working on the LS-into-91 Volvo 740 Pickup. Prep work involved beefing up the rear subframe & engine crossmember.
I decided to make a double-wall version of the rear subframe
welded two together
Then added cross bracing when that was all done
Added outliers, so I also doubled the rear brace bushings
After that was done, I worked on the front crossmember reinforcements
Tie plates were added by Volvo for later models that had the whiteblock L6. The right side bracket was still available, so I bought that & used it to make the left side
pxl_20250108_220229256-jpg.94062
reinforced a bunch of unfinished seam welds
added some additional bracing where they are known to crack on V8 installs
additional boxing on the top side
decent pan clearance, I added 1.125" mount spacers (intended for V8 into Datsun Z swaps)
converting to 6AN lines for the PS rack to pump
More work to go before I get to pull the stock drivetrain & start the test fitting.
Got the 2 speed eFan sensor bungs welded into the 2 radiators intended for the V8 740, and the V6 280Z. Using the same BMW sensor I used on the X1/9 install. My aluminum welds are just not clean enough for this type of work.
What is it that welders put an oven to heat up before welding?
My Dad's welder guy had a refrigerator and an oven in his shop when I was a kid, WTH? I asked, welding rods in the fridge and the oven was to bring up the temp on some kind of metal before he started working on it. That's something I never learned, like playing guitars, that I regret. Practice, practice, practice...:blush:
  • Agree 1
  • Who's Online   2 Members, 0 Anonymous, 1,111 Guests (See full list)
