With no load from a pump do you think the eccentric will really have much effect?  The weight of the sprocket is far greater than that tiny cylinder of steel, placed near the center of mass.  I tend to leave well enough alone.  Just a counterpoint...
I've never heard of any vibration issues due to the eccentric, so I tend to agree.  That said, it's one more thing in the torque stack that could cause the bolt to come loose.  I wouldn't take it apart to remove it, but if the bolt ever needs to come out for something else, I'd ditch the eccentric.
I would think the pump lever would absorb a lot of the energy that causes vibration but without it installed I would remove it. Now admittedly it has a low mass and a small radius but it shouldn't be very challenging to remove
  • Who's Online   2 Members, 1 Anonymous, 1,452 Guests (See full list)
