Stereo tape in 280z (Clarion Radio Connector)
19 hours ago, Mark Maras said:
1st gen had the antenna switch on the right side of the radio like the one pictured but they were AM radios.
Yeah.. and always Hitachi's..  I never saw a Clarion in that configuration with AM and FM and the antenna switch like that.  Oh well, MH77280z, congrat's with your buy!
  • Agree 1
Now I think for once we all should appreciate the 2+2 for bringing a Clarion AM/FM technology together 🤣
I dont have the female end of this connector under my dash. Seems like this is the only modification the previous owner made. Basically cut out the connector.
I could not locate the wiring diagram for the radio in the FSM. I am sure there are power and speaker wires all in this connector.
Any tips?
I always appreciated the 2+2 as a tall guy well over 6 feet i appreciate the rooooom... in the car!
Are you sure? It should be in the chassis-service manual in the electronics section.. otherwise it should be somewhere on the internet i think.  I can't help you as i don't have a clarion of that type.  (The one with the fuse is the 12v+ i guess.. and with a ohm-meter you can find out the rest? 🙂)
OK, so my car has this connector still there with wires cut which you see connected in #5 in the pic.
This Calrion from the 76 280z 2+2 has a different connector!!!
I need to try my luck with the guy i bought the Radio from. May be he still has the parts car.
Luckily, I found that the connector from my original radio harness was complete (male/female). Cut the Clarion connector and tested with the original black radio connector and it works great. Radio lights up!!! Good reception even with no antenna extension.
I had to directly connect the speakers with the radio speaker wires as I have the 2 new Polk Audio speakers installed. I think this is a mono radio so planning to just connect the two speakers in parallel and call it a day.
Probably will buy a cheap FM broadcaster to send music to the radio ... but i dont listen to anything when driving it anyway.
15 minutes ago, Yarb said:
Got to know… Where did you find the original connectors?  Needle in a Hay stack!!
For my 280z I found the connector still attached to the harness. The wires were just cut to accommodate the new stereo. So got a bit lucky three.
There seems to be few website which sell these as well, you have to Google but i did not search them properly.
  • Agree 1
Data from various pages on here:
Blue is +12V power in. Hot when in ACC and ON.
Green/White is panel illumination high side. Goes to the headlight switch.
Red/Blue is panel illumination ground side. Goes to the rheostat.
The two wires (White and White/Black) from the radio are for speakers. I am planning to add a small AMP in front as the max volume is a bit on the low side output.
Using external black cable to ground the radio to the chassis.
Next i need to tackle the aftermarket antenna. It only has two wires as compared to the OEM (going for $1K+ on ebay). My aftermarket just extends fully when energized.
  • Who's Online   2 Members, 0 Anonymous, 1,305 Guests (See full list)
