I recently complete my restoration of my 73 240Z.  I have no plans to do another one. I have lots of leftover parts. A few new but most used but in decent shape. A lot of the used stuff is in good condition but I figured once I had it off it was the same amount of work to install new. Most of the stuff I will give away for free if you pay shipping other stuff I'll sell at bargain basement prices. Here's a list of some of the things I have.  If you're looking for something not listed let me know and I'll see if I have it.  Unless otherwise noted all parts are from 72 & 73 Z's.
Original kick panels
Glove box interior, cardboard (New)
Clutch slave cylinder for 73 (new)
73 Intake manifold w/ flat-top carbs & all the pollution crap
73 exhaust manifold
73 auto trans w/ flex plate, spacer, shifter assy, starter (conditions unknown.  I know it worked when I got the cars but did not shift smoothly.  Didn't worry about it because I was converting to manual.
72 engine less intake, carbs, trans and starter. condition unknown came with the car, I was told it had been rebuilt but don't know for sure.
(2) York A/C compressors used in ARA dealer installed A/C R12 system. Clutches work and compressors turn freely
73 Timing set, used but in very good conditions
Engine mounts
Trans crossmember & trans mount.  Crossmember could use some metal reinforcement
A/C condenser, good condition, I flushed it, cleaned it and pressure tested it
Complete set of rocker arms checked out by machine shop most were in great shape but 2 were still useable but not 100% I replaced the whole set
(4) original steel rims (sorry no hubcaps) no dins or dents but could use sandblasted and painted
Complete dealer installed ARA ac/heating duct work and underdash enclosures
2 pcs plastic fan shroud not sure what year its from 260 or maybe early 280.  very good condition
Rear differential safety strap
Lots of other stuff.  I rather some use it instead of tossing it in the trash
  • Like 4
https://www.classiczcars.com/topic/68741-leftovers/
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
